I have a 14,000 gallon pool with plaster walls and a built in hot tub that flows into the pool when the pump runs. I recently had to re-fill almost 13,000 gallons of fresh water due to an unfortunate accident with the reverse osmosis company that's paying for my re-fill fees. The reason why I needed the RO was because my CY was 250ppm and CH was 410ppm.
I'm all in on the TFPC method, but need some help on this restart. My current readings are:
CH: 300ppm
CYA: 40ppm
pH: 8.0
FC: 550ppm (it was 11 drops of the Taylor K-2006 test)
CC: 0.4ppm (2 drops from K-2006)
TA: 180ppm
I'm a total newbie when it comes to this, so any advice would be appreciated, I'd like to avoid having to go the RO route ever again, not my funnest experience to waste that much water.
Thanks again for this site, it's awesome!
CH: 300ppm
CYA: 40ppm
pH: 8.0
TA: 180ppm
