Results 1 to 7 of 7
Thread: Sodium Bromide
    Jul 2016
    Rydal, GA
    5
    Sodium Bromide
    I am a rookie pool owner and my pool got contaminated with what I later learned was pink algea. I tried to super chlorinate and brushing but it came back. I looked on Internet and found a pink treatment. I added to my pool but now have concerns that I have made a bad move as it is Sodium Bromide. I need to know if I did make a bad move and if I did what do I need to correct.
    Smithy4
    18 ft round above ground pool
    7600 gal
    JoyfulNoise's Avatar
    May 2015
    13,236
    Re: Sodium Bromide
    What product did you add and how much of it did you add in total?
    Matt
    Jul 2016
    Rydal, GA
    5
    Re: Sodium Bromide
    Pink treatment and 1 lb was added
    Smithy4
    7600 gal
    May 2015
    13,236
    Sodium Bromide
    Quote Originally Posted by Smithy4 View Post
    So in your pool volume, that's going to equate to 15.8ppm sodium bromide concentration in the water. That's about half way to what people add when operating a bromine pool (typical bromide bank is 30-50ppm). So, unfortunately, you will experience a constant chlorine demand from the bromide being converted to bromine by chlorine. Bromine is a sanitizer but it does not get stabilized against UV loss like chlorine does with CYA. So the bromine will get used up more rapidly than the chlorine and it will constantly use up chlorine in the process.
    You can either choose to operate your pool as a high loss chlorine pool OR you can dump your water and refill. Up to you.
    Matt
    Re: Sodium Bromide
    If you can track daytime chlorine losses and nighttime chlorine losses for a few days, we can help you decide what to do.
    Support the site
    Jul 2016
    Rydal, GA
    5
    Re: Sodium Bromide
    I just got a new K2006 test kit but still in the process of learning how to use. I have check night time use with test strips and I have little loss of free chlorine but in daytime I go from 7 ppm to zero in about 6 hours. Temperatures have been in mid 90's with no cloud skies.
    Smithy4
    7600 gal
    May 2015
    13,236
    Re: Sodium Bromide
    We really need proper test results, strips are too unreliable. We need the full set of numbers -
    FC
    CC
    TA
    pH
    CYA
    CH
    And we need accurate measures of daytime loss and overnight loss. This will tell us how much chlorine is being consumed by the bromine and whether or not it is worth it to continue operating the pool the way it is. If losses are too high, then the amounts of bleach needed to maintain proper sanitation levels could cost more than just dumping the pool water and starting over.
    Matt
