Thread: Test results in, needing advice
    Jul 2016
    Park River, ND
    14
    Results are:
    • FC - 0
    • PH - 8+ (5 drops so assuming I add the recommended 1.43 qt muriatic acid)
    • TA - 130 ppm
    • CH - 100 ppm
    • CYA - dot never disappeared so I assume <30 ppm
    • CC - Combined Chlorine 0
    Water temp 75
    Using Taylor 2006 kit
    Would appreciate advice. Thank you!
    10K, AG, 3000 GPH Krystal Clear Sand Pump, Taylor K-2006
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Test results in, needing advice
    pH first. Target 7.5 in case you overshoot. Get some CYA dissolving in a sock, use Pool Math to aim for 20. Add enough chlorine to get to 3 (Pool Math again).
    How's the water look?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2016
    Park River, ND
    14
    The water looks perfect. How do I determine how much CYA I have now if the test did not tell me?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    If you never put a puck or shock or any solid chlorine you can assume 0.
    Jul 2016
    Park River, ND
    14
    Ok, Thank you! When do you recommend testing again?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    If it is a fresh fill then it is 0 and I would add 30 ppm If not, then add 20 and see where you end up. More here on adding CYA and other chems, Pool School - Recommended Pool Chemicals
