Thread: algae and pool slamming?
    Jul 2016
    Bennington, NE
    1
    Question algae and pool slamming?
    This is my first pool set up and wowza what a headache. This site has definitely been a great help though. I made the mistake of not adding stabilizer right away. Then went on vacation to disneyland. Came back to a green slimy mess! It has been 3 weeks and although it has gotten a ton better, I'm still dealing with cloudy water. I replace the pump that came with it, with a larger pump and that has helped. I have just been using the shock chemicals from the store. Im still trying to get my CYA up and will retest tonight. I was reading how to slam your pool. With my CYA at less than 20 it says 10 for chlorine. Is that the level I need to get it to? I'm confused and this headache isn't helping. lol
    Mod Squad pooldv's Avatar
    DFW, TX
    24,470
    Re: algae and pool slamming?
    Welcome to TFP!
    Yes, you want to raise FC to shock level for your CYA.
    Jun 2015
    Jackson, NJ
    123
    You can dump some instant pool conditioner in the water to raise your CYA. Its pricey, but its immediate.
    42' natural free-form pool, vinyl lined, 6' deep end, 21,400 gallons
    2 HP Hayward Superpump, Hayward Aquarite SWG, AquaComfort 125k btu heat pump, 350lb Hayward Pro Series sand filter
    2 skimmers, 2 floor drains, 10 returns (6 in the pool, 2 in the steps, 2 in the swim-out)
    TF-100 Test Kit
