Thread: TFP method. Suddenly getting algae.
    timthek's Avatar
    May 2013
    Philadelphia Suburbs
    37
    So I have been doing TFP since last summer with the Liquidator to much success. Here are my numbers:
    20-25,000 gallon in ground (pebbletec surface - full sun)
    CL 5.5
    PH 8.0 (keeping it down is a constant battle)
    CYA <50
    CH 260
    TA 80
    Single speed pump running 6-8hrs a day
    I just shocked the pool and will adjust PH once chlorine has stabilized
    I don't think I should be getting algae with those numbers..... any thoughts?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    Re: TFP method. Suddenly getting algae.
    Assuming you have kept your FC above 4 at ALL times (for a CYA of 50), then signs would point towards you not developing algae. The above numbers are just a point in time.
    Are these results made by you with one of the recommended test kits?
    Did you have a green pool when you opened this spring?
    What is your CC level?
    Sorry for all the questions, it's just how we analyze situations.
    The TFPC method does not recognize shocking as a reliable method to do anything really. You have algae so you will need to SLAM your pool but the above may help us learn why the algae appeared in the first place.
    I can almost be certain though that FC got too low at some point and algae gained a foothold. It's a pretty straightforward scenario we see all the time.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    timthek's Avatar
    May 2013
    37
    Quote Originally Posted by bmoreswim View Post
    Yes, I use the recommended test kit. My pool was not green when I opened it, just cloudy. CC is zero or close to it.
    FC did dip to 3 one day when I an out of CL but I got more that day and it was back up the next day. That was probably last Thursday. Can one day dip really allow algae to develop even if my CL level went back to 5-6ppm in under 24hrs?
    Tim
    20,000 Gallon In-ground - PebbleTec pool surface
    DE Filter with Pentair Whisperflo WF-23
    Pool Season: May 1 - Sep 30; Full Sun
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Perform the Overnight Chlorine Loss Test to see if a SLAM is needed.
    timthek's Avatar
    May 2013
    37
    Quote Originally Posted by pooldv View Post
    I did lose a little CL overnight so I'm going to keep hitting it. Off to the pool store to grab another 5 gallons.
    Tim
