Thread: Swimquip DES60 Collection Manifold Cracked - Replace? Repair?
    May 2015
    Vista CA
    8
    We just opened up our DES60 for cleaning. The collection manifold has a few cracks. No one seems to have the parts in place. Can I use JB Weld or some other material (Plast-Aid, Goop, ???) to repair the crack?
    Paul
    15,000 Freeform IG/Spa, Gemstone Desert Coral, 2x IntellifloXF, EasyTouch, Sta-Rite DES 60, RayPak Versa Millivolt (399K)
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    Re: Swimquip DES60 Collection Manifold Cracked - Replace? Repair?
    The following link from a reputable dealer shows you manifold to be obsolete. http://www.inyopools.com/pool_parts_..._assembly.aspx
    At least it give you the manufacture numbers for what you need. I did another search and found this dealer who would require a call to check availability of part number 12a in the list. http://www.partswarehouse.com/Sta-Ri...-01-s/8897.htm
    IMO any type of repair pudding will not last long if it is truly cracked. The tank top lid on my Hayward DE filter has looked like it is cracked for years. Were you seeing any DE in the pool? Was the pressure normal when running?
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    May 2015
    Vista CA
    8
    No DE in pool. The pressure was high, it was time for a backwash. We opened it up and found a few cracks. I can see through them, so they will pass water. The goal is to fix the problem before the part becomes unserviceable - perhaps "A patch in time saves nine"
    Paul
    May 2015
    Vista CA
    8
    I used JB WaterWeld for a patch. After cleaning and sanding, I spread the material over a large area around the cracks and let it cure. If it bonds well to the plastic, then it should support the area and prevent further cracking. If not, I'll find the chunk next time I open the filter.
    Paul
    Jul 2016
    Boston, MA
    4
    One other thing to look into is plastic welding. I didnt really think it wold work but they sell kits on Amazon that literally melt the plastic back together. Doesnt always look great but wouldnt matter in your application. I Have fixed many many items that I thought never could be fixed. Look up the vidoes on airless plastic welders and its a pretty cool thing.
