Thread: Quick Question on Disconnecting SWG
    Mar 2016
    Medford, Oregon
    180
    Question Quick Question on Disconnecting SWG
    I want to clean my IntelliChlor IC20 SWG for the first time. The instructions in the manual are quite straightforward. However, in addition to disconnecting the power cable from the SWG to the EasyTouch 4 control panel, the manual says to cut the AC power from the control panel as well. Is this referring to throwing all circuit breakers on the control panel? In doing so, will any of my automated settings be wiped out?
    Thank you.
    Kit
    14' X 11' rectangular in-ground spa; 2,360 gals; plaster/gunite; SWCG (Pentair IntelliChlor); Pentair Intelliflo varaible-speed pump; EasyTouch4 control system; cartridge filters; auto cover
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Re: Quick Question on Disconnecting SWG
    Your automation will retain its saved settings, just like when the power goes out during a storm.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mar 2016
    Medford, Oregon
    180
    I should have expected that there would be an ion-lithium battery (or similar) as a backup in the event of power disruptions. Also, I erred on the side of caution & turned off both the control circuit breaker , as well as the breaker for the pump. I used the LED lights on the IntelliChlor display to determine when the AC power had been shut off.
    Thank you for the response.
    Kit
