Thread: Paramount Valve Head Mounting Height Above Waterline?
    Jul 2016
    Boston, MA
    4
    I feel like I read this someplace. My pool ended up being higher than this valve and it was unexpected and before I ask the installer to cut these and increase them I wanted to see if this is true or maybe I am mistaken and what happens if it's below the water line?
    Thank you
    Apr 2015
    tucson, arizona
    1,121
    Re: Paramount Valve Head Mounting Height Above Waterline?
    When you open up to service the water will flood out and make it more difficult to replace module or o-ring
    Feb 2015
    Chandler AZ
    933
    Have them raise it - for the exact reasons stated by kadavis. If the installer baulks at the idea, have them specifically show you in the install manual where it says that it's okay in it's present position.
    Also, you can give Paramount a call directly - at 1.800.621.5886 - and verify the info.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
