Thread: It does what? Is this possible
    Jun 2011
    Northeast Ohio USA
    178
    I have not been on the forum for awhile, but I seem to recall CYA (cyanuric acid) stays in the pool.
    I always had trouble raising CYA levels, but I doubt the physics have changed much in the last few years.
    Any comments? Thanks.
    http://www.menards.com/main/health-w...23585907469243
    Description & Documents
    Instant gratification when added to pool. No wait time to swim. Will not cloud the pool and is ready to use. No mixing is required.
    12.5% strength
    No settling on the bottom of the pool which creates stains
    Liquid pool chlorinator is one of the best options to reduce cyanuric acid levels
    For above or inground swimming pools
    1 gallon
    Made in USA
    Vinyl In-Ground (vinyl) - about 21600 gallons (18x32 Grecian)
    Hayward DE (model 7220?) filter with Multiport valve
    Challenger Hi Flo Pump (3/4 HP)
    Intex SWG
    leaky/non-functioning Raypak Versa Natural Gas Heater *removed*
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: It does what? Is this possible
    It is a bit of a misnomer and poor labeling. It will not reduce the CYA, but rather just stop it from increasing as the liquid chlorine is not bound to CYA like dichlor or trichlor.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Liquid chlorine will not reduce cyanuric acid levels directly. Using it instead of trichlor or dichlor will "reduce cyanuric acid levels" because you're not using them? It's confusing verbage.
    There's some complex chemistry involved but maintaining higher FC levels (think shock level FC) for extended periods can accelerate the decomposition of CYA, but in normal maintenance, using liquid pool shock will not actively lower CYA levels.
    Isolated Spa - 345 Gallons
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I think they are implying that USING it instead of pucks will prevent cya increase...true
    Dolphin E10 Cleaning Robot.
    Jun 2011
    Northeast Ohio USA
    178
    Ahhh, subtraction by addition (or non-addition).
    Must be the same group that manages the national debt.
    Thanks for the responses.
    Intex SWG
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,205
    Quote Originally Posted by shortdogOH View Post
    Support the site
