Thread: CYA question
    Jul 2016
    Hudson/New Hampshire
    23
    CYA question
    This has probably been asked, but does CYA ever lower on it's own, or once I reach the level it will maintain? Does anything effect CYA like evaporation causing it to concentrate or adding water/rain diluting it?
    Hudson New Hampshire
    11000 gal AG 21ft by 52 inch deep round since 7-1-16
    Clearwater II 2hp/2sp cartridge filter
    Well water to add to pool but filled with plain water truck
    TF-100
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: CYA question
    CYA naturally degrades very slowly, maybe a few ppm per month. Splash out of the pool is the biggest loss, so,if there are lots of kids, maybe a swimming dog or two - you will see loss there.
    You have it correct, if water evaporates the CYA goes up but right back down when you add water back.
    Support the site
    Jul 2016
    23
    Re: CYA question
    Thank you very much. It's slowly starting to click! Best resource ever
    TF-100
    May 2014
    Franklin, NC
    9,197
    Re: CYA question
    Quote Originally Posted by shandoug View Post
    Best resource ever
    Thanks!
    I will just add that TFP is staffed by volunteers and folks like you keep the lights on with donations
    Support the site
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: CYA question
    CYA testing is a little tricky. Try to recreate the same environment for testing, i.e. same sunlight, back to sun, vial at waist level, vial held with two fingers at the top, etc. If it was not bright out or you held the vial in direct sunlight it will give you a lower reading. This may not be the case but it could be skewing the numbers. Without water replacement your CYA should not change that much.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
