Thread: Changing filter laterals
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    I have a Hayward S200 sand filter and it seems the lateral lines are broken as sand is being blown back into the pool. I have ordered the new laterals and we are replacing the sand and all o-rings for peace of mind. Does anyone have any tips? Any surprises I should look out for? I have viewed videos and it seems pretty straight forward but in my experience hardly anything is ever as easy as it seems at first. Thanks.
    1st time pool owner with 3 months of experience.
    25,000 gal, IG, vinyl, sand filter.
    ColorQ PRO 7 test kit
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: Changing filter laterals
    Don't crank on the new laterals... they are delicate and if you do crack them, youll be back at square 1... Check your main lateral tube too.. those crack as sell. When you refill the tank, make sure to add about half water before you dump in the sand.. the weight of the sand will break the laterals too...
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    So my filter is up and running again. YAY! Now to start SLAM #2!
    This was what we found inside the filter. We had back washed before shutting down.
    All cleaned out. The inside of the laterals were just as bad, they were not stopping anything from going back into the pool. We had 2 that were obviously broken, had visible cracks, the rest were just very very dirty.
    New laterals in place and ready for new sand.
    It took us about 3 hours start to finish. Taking the bolts out and putting them back in was the most time consuming, our drill battery ran dead half way through so wrench and ratchet the rest of the project. A LOT of stuff was blown back into the pool when it was first started up. I'm assuming it was everything inside the pipes from before as now the water going back into the pool is nice and clear.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Looks like that thing needed some love!!!!
    Don't forget to add water before sand so you don't crack the new ones
    13500 gal
    Herwick's Avatar
    Apr 2016
    Ardmore, Ok
    49
    Quote Originally Posted by cj3737 View Post
    We did, thanks for the tip! We also used a hand trowel to make sure there was a good base under the laterals before dumping in the other bags.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    13500 gal
