I recently had a 24" above ground pool installed. I have added rope lights around the outside of the pool. I need to make those where no on can be shocked if it where to be pulled from the mounts into the water is there a power supply adapter that will ground the a.c. in this instance. Or do you have a suggestion of what company to use for a safe lighting experience
