Thread: Cleaner Recommendation
    Jun 2016
    PA
    12
    Looking for a recommendation for robotic pool cleaner.
    I have a 16x32 vinyl pool; approx 25K gallons. Deep end is a kind of weird 3D trapezoid (picture attached) with each side having slope from the sides. Pool is surrounded by trees; I can have it perfectly clean and the next day there is debris laying on the bottom. Frequently this is pollen/dirt from trees. Dirt often accumulates in the corners of these slopes.
    Also have a set of aftermarket steps as seen in the picture. I don't care if the robot can't clean that, but just don't want them to cause the robot any problems.
    16x32 in ground vinyl pool. 48 square foot DE filter (though using fiber clear, DE alternative). 3/4hp super pump. Chlorine.
    Jun 2011
    Long Beach, CA
    2,790
    Re: Cleaner Recommendation
    There are many to choose from but you might want to state your budget to get more responses.
    Jun 2016
    PA
    12
    Top is $1k; it's worth it to me if it really works and saves me time and the pool is always ready to swim rather than me vacuuming for twenty minutes every time.
    I ask for recommendations because I know at least two people who bought robots that didn't work out for their pool; either couldn't climb right, got stuck in a corner, etc. What is the average return policy like if it doesn't work out for a particular pool? Anything special about the way my pool has those sloping sides?
    Jun 2011
    Long Beach, CA
    2,790
    Many dealers have 30 day trials for cleaners. Look up your nearest Maytronic dealers and see if any have that policy. I like the Maytronic S series or Active models depending on which line your dealers have.
