Thread: Changed sand in Filter, still getting sand in sight glass
    Jun 2015
    Benton, AR
    11
    About a month ago, I decided to change the sand in my pool filter. I have no history of the pool (how old, maintenance issues, etc.) and was having a masssive algae issue. So we decided to change the filter sand before doing a SLAM.
    In the process of cleaning it all out, one of the lateral arms inside the filter arm broke. I replaced the arm and finished replacing the sand. Ever since then i have been getting sand in the sight glass after backwashing and rinsing. I pull the glass, clean it out and the next time there is more sand. My dolphin robot runs all the time and I haven't yet found sand. And because of the water isn't swimmable I can't tell if there is sand on the bottom of the pool.
    So is this normal?
    26k GALLONS, HAYWARD 1HP FILTER PUMP
    HAYWARD 300# SAND FILTER - NEW SAND AS OF 6/16
    VINYL LINER, DOLPHIN DX3S (HERBIE)
    7 YR OLD SON, ASKING FOR WATER: "I FEEL LIKE A DEHYDRATING CRAB"
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: Changed sand in Filter, still getting sand in sight glass
    What is the model of sand filter?
    I know someone here had noted the S244T hayward, you have to be careful as the lateral
    can leak sand where it joins the assembly if not folded the exact way.
    Dolphin E10 Cleaning Robot.
    Jun 2015
    Benton, AR
    11
    It is the S244T. I folded them down to maybe 20 degrees from level.
