Results 1 to 7 of 7
Thread: Few spots of scaling
    May 2014
    Inverness Fl
    53
    FC 7
    CC 7
    CYA 50
    pH 7.8
    TA 90
    CH 275
    Got a few spots of calcium scaling showing up (took a couple of small crystals-with MA fizz test). Not a lot-about 5 or 6 small one. Wouldn't think with my test numbers that it would happen. But been really hot-humid here in Fl., have taken to using fountain like Dave S. (thanks) to lower water temp. Don't know if this has caused it, have not had it before. Just efflorescence.
    Should I be concerned about this to much? I just take a nut pick and scrape it off. If I don't get 100% of it off, will it matter. They are really small areas, and I didn't want to have to do a MA wash of each spot.
    mid 2014 12 X 30 12k gallons IG Plaster\Fl Gem Finish. StaRite\Pentair DE filter. StaRite\Pentair IntelliPro VS Pump. Pentair UltraTemp Heat Pump Unit. Intellichlor IC40 salt system (not up and running yet)
    Very hard well water-no iron. TF-100 Test Kit (the best)
    Jul 2011
    Arizona & California
    805
    Re: Few spots of scaling
    See this link for possible issue with your plaster: Calcium Nodules in pools
    May 2014
    Inverness Fl
    53
    onBalance
    I read your pdf paper on this. So am I correct (since these are in the grout between tiles), that I should just do nothing for now until the calcium is exhausted from underneath. Won't hurt the pool overall.
    Thanks
    Jul 2011
    805
    Now that you have read the article about nodules, you know that those growths have nothing to do with the balancing of the pool water.
    Since those nodules are forming on the grout of tiles, go ahead and scrape the nodules off, they may not return. But you could also try to fill in the pinholes and cracks (beneath or under the nodules) with epoxy. That would ensure that nodules won't continue to form.
    There won't be any long-term damage to the pool.
    May 2014
    Inverness Fl
    53
    onBalance
    In trying to seal a pin hole in the grout (color-dark gray), do you have a recommendation for a good underwater epoxy cement.
    Thanks
    Jul 2011
    805
    Since this is only for filling in a small pin hole crack, I would think that any kind of two-part waterproof epoxy would work fine and do the job.
    I have also seen hardware stores sell a grey or black epoxy too.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    My PB uses pool putty For stuff like that. He mixes white and black to match our grey.
