Results 1 to 9 of 9
Thread: Lowering TA-pH is at 7.2 now & aerating now-add acid or wait
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Hi all,
    My TA is currently at 100 (I want to get it down to 70-80 so I can add borates) and my pH is currently 7.2 & I am currently aerating, can I add acid now to bring down both pH & TA or should wait until the pH up higher before I add acid?
    Thanks
    Bob
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Lowering TA-pH is at 7.2 now & aerating now-add acid or wait
    Wait. Let it raise back up to 7.6 and then lower it again with acid.
    Bob_Funk's Avatar
    May 2009
    113
    Thanks FPM,
    I will wait until I hit pH 7.6, pool calc. says add 60oz. acid to lower pH to 7.0, how much TA reduction should I expect with 17,000 gallons?
    I do not want to overshoot TA
    Thanks again
    Bob
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by Bob_Funk
    Pool calc will also tell you how much the TA will drop; see the "effects of adding chemicals" section at the bottom.
    --paulr
    BBB "Intermediate Swimmer"
    Bob_Funk's Avatar
    May 2009
    113
    Quote Originally Posted by PaulR
    --paulr
    I did not catch that, thanks Paul
    Bob
    Guest
    rely on your testing to see how much the pH has changed or the TA dropped and remember that the TA test is only precise to +/- 10 ppm so don't micromanage!
    Bob_Funk's Avatar
    May 2009
    113
    Thanks waterbear,
    I will, I was just looking for an idea of how many times I would have to add acid & bring the pH back up, looks like 2 or 3 times to get where I want it
    Bob
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    fwiw, overshooting TA (if you mean getting it too low) is one of the easy problems...just add chemicals. also, 20 mule team borax raises your TA as waterbear notes in his article. in my case, it was by 20ppm.
    11,969
    Borax raises TA, but for simply raising TA with little impact on PH - Baking Soda is a better choice.
    Raising PH - Borax and Soda Ash - though both will raise TA in varying amounts
    Aerating - raises PH without affecting TA
    Raising TA - Baking Soda - will raise PH very little.
    Use the "effects of adding chemicals" section of the pool calc to see the various numbers.
