Thread: "Concentrated" bleach -- what does that mean?
    OutWest's Avatar
    Jul 2016
    El Dorado County, CA
    35
    I was at Home Depot yesterday and decided to check out their bleach. Much to my surprise they had different ones--for outdoor and indoor, a concentrate that said it had to be diluted, ya da ya da ya da. Nowhere on the label could I find the percentage of actual bleach (12.5% etc.) that has been discussed here in the pool school articles on chemistry.
    Has anyone used this stuff? Is the concentrate too strong for pool use? I could see no additives listed on the labels.
    8,900 gal in-ground gunite lap pool; self-cleaning Jandy 1.5 HP Pro Series E-pump system; Jandy CV340 pool/spa filter with four cartridges; Propane heater (rarely used); motorized pool cover.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,264
    Re: "Concentrated" bleach -- what does that mean?
    It won't be too strong for pool use, but I would not buy anything that doesn't have the % and manufacture date on it.
    The most expensive bleach I've seen was in a spray bottle as "stone and brickwork cleaner" 3% sodium hypochorlite, 20 oz spray bottle for $7.99 (around $50 per gallon for 3% bleach)
    2nd highest I've seen was "driveway cleaner" with 3% bleach and $20 a gallon.
    You want 8.25% minimum and around $2.50 / $3.00 per gallon. Sometimes the same stores have pool shock (liquid) at 10% sodium hypochlorite and around the same price. Get the freshest you can find - manufacture date 16150 means 2016 and 150th day of the year. The highest I've seen is 12.5% and I've read that it's a practical manufacturing limitation that limits from being very much higher.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    +1 to not buying anything without the percentage clearly marked. It varies some by state but here is how it usually works. These are all the same product, just different strength.
    6% regular bleach
    8.25% concentrated bleach
    10% liquid chlorine
    12.5% liquid shock
