Thread: Please Help. Intake Valve Leaking at Intex hose connection
    Jun 2015
    Sacramento
    1
    Hi,
    I was wondering if someone on here can please help me out with a leaking problem that I just discovered today. I have a 1 year old Legacy 17' x 52" above ground pool. I am using the original inlet/outlet valves that came with the pool and connected a Intex 3000 gph sand filter and Intex saltwater generator to them. My inlet/outlet valves did not come with any O rings or gaskets to use in between them and the sand filter intake/salt water generator output hoses. The intex hoses also did not have any gaskets or o rings so I tried to make my own out of spare parts and that worked for about a year during which time I ordered what I thought were the correct gaskets from Intex (2 different ones). I noticed last night that the inlet was leaking so I attempted to replace the home made gaskets with the new gaskets from Intex only to discover that they do not work and the inlet is leaking worse than before. I also tried to put the old home made gaskets back in and that didn't help either. Do any of you know what gaskets or o rings will work on the intex sand filter hoses? I tried a couple of local pool supply stores and home depot with no luck so I am praying some one can help me out on here.
    mulia's Avatar
    Jul 2011
    NE Ohio
    100
    Re: Please Help. Intake Valve Leaking at Intex hose connection
    The intex hose gasket should work.Amazon has them.
    INTEX AGP 15'x 48", 4440 gals.,INTEX 2650 gph pump w/ 16" sand filter, Hayward widemouth skimmer,INTEX SWG-CS8110, 1 1/2" hard plumbed PVC, Lil' Shark vac w/ leaf canister, INTEX floating LED pool light, solar cover with polaris solar reel, Access pool steps 200600T, TF 100 test kit, "The Slime Bag" x-tra polishing 18" x 30"
