Results 1 to 12 of 12
Thread: How "clean" is the gunite shell supposed to be for plaster application?
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    My pool was "cleaned out" on Friday. It rained a bit during the clean out, but water isn't the issue. It just doesn't LOOK clean. There's debris from the cutting of pipes and placement of of fittings/lights, etc. and still a layer of dirt on and around the drains.
    Plaster was supposed to be tomorrow. It's been moved to Tuesday due to the rain in Sat. Should I bother the PB in the morning about this or is this normal?
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    May 2016
    fort worth, tx
    123
    Re: How "clean" is the gunite shell supposed to be for plaster application?
    When ours was initially cleaned it looked pretty good, but by the time the plaster guys got there almost a week later, it was looking pretty rough, just from some rain we had, wind blowing dirt, leaves, etc... I was concerned, but just decided to watch the show, and see what happened. If I remember right, they pretty much hosed it all down and got it cleaned up again before getting started, while at the same time other guys were setting plastic etc. Good luck with the plaster!! I'd think Tuesday is still a good day to plaster as you'll have time to get it filled, and have the guys do the equip start up before the weekend.
    Construction began 5/2016. IGF pool. 41' x 21'. Jandy DEV60, Jandy 2hp 2sp pump, Polaris 280 Black Max, Rainbow 320 chlorinator, Jandy JXI 400, Jandy iAqualink, Jandy LED's. 2'x2'x10' rock weeping wall. Dive rock. Tile/Plaster: NPT Silverstone AquaMarine Decking: Stained Stamped Concrete/Stonescapes Aqua Blue with glass beads and abalone. http://www.troublefreepool.com/threa...-Fort-Worth-TX
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Denise, I had forgotten what my gunite looked like before plaster, so I did some checking. I'm on my cell, and I don't know how to post pictures with it. If you want to see some photos from my pool build (link in my signature) of my gunite AFTER the clean up crew, you can see photos from p. 32 to page 42. And on page 32, post #625, I wrote what the cleanup crew told me how the plaster crew would clean up more right before they plaster. To quickly recap, due to different delays, I didn't get plaster for a couple of weeks after the cleanup. That's why there are so many pages of my gunite after cleanup before plaster. Zoom in and you can see the 'rust' stains and other stains. Maybe the photos will help you compare to your gunite pre-plaster. Without pictures from you, I can't say.
    Remember, every plaster company is going to do things a little differently. I do think since they have good warranties on the finish, they will want to do each step well to avoid problems.
    Paris also posted on my build thread some photos of his pool right before plaster. (somewhere between p. 32 and 42). Maybe some others can share photos of their gunite before plaster.
    I hope this helps. Let me know if you need me to name some specific posts for pictures.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    They will have someone do the last clean up when they get there BUT I would also watch to make sure they do. I don't trust anyone.
    Kim
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,236
    I had the same experience as technobuyer. They set up a big tarp over it, and then went crazy with the pressure washers and removed every last bit of anything before starting on the plaster. Here's a picture of them cleaning it under the tarp.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Thanks everyone! That makes me feel better!
    Technobuyer, thank you for being so reassuring! With all the issues and lack of quality workmanship, I'm concerned they are just gonna spray the plaster over a dirty debris filled she'll and then we have REAL problems!
    Suz- I have been working so much, I haven't had the time to post much. Thank you for referencing your build page for me to look at! VERY helpful!!
    Kim- I no longer trust anyone on this build either! I'll be here in the morning for plaster, for sure! I'm supposed to work at 3 (leave by 2) tomorrow afternoon. We'll see... I'm off Wednesday for acid wash and fill and off Thursday for CANNONBALL (hopefully)!!!!
    jet- thank you for the picture and the info!!! I can only pray my plaster crew is just as detailed!!
    Denise-TFP Guide
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Here's my "cleaned out" pool
    Denise-TFP Guide
    May 2016
    Woodland, Ca
    234
    I highly recommend the cannonball. According to my 7 year old, you should scream "cannonball" while in the air.
    Your pool looks great, hope everything goes as planned.
    Build Video 2016 -- Solar Pad 20.5K gunite (37'x15') rectangle (3.5'-7') deep-- MicroFusion Laguna finish -- Jandy VS pump, cartridge and iAqualink RS -- Polaris 360 Black -- 2 Laminar jets -- 2 nichless 30w color led -- 550sq/ft Heliocol solar -- Soft water auto fill -- Stenner 17gpd
    May 2016
    fort worth, tx
    123
    Mine looked at least that bad, and likely much worse.
    My 10 year old son took the honorary first cannonball this afternoon. Good stuff!
    needsajet's Avatar
    Jan 2016
    4,236
    Yeh, we wanna know who gets the first bomb... and can it be off the top of the scupper wall? Maybe you and hubby or one of the grandies off either end from the columns? Just don't try to kiss in mid-air.
    Aug 2014
    Houston tx
    2,524
    Denise, for our pool, the plaster crew cleaned the shell the same day they came to plaster. So, don't worry. I think you'll be fine.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Quote Originally Posted by CaptainCannonball View Post
    Sounds like he has the sequence down pat!
    Thank you!
    Quote Originally Posted by Technobuyer View Post
    Tomorrow I hope to catch up on some of the builds I have been following (like yours). Congrats on reaching swim day!
    Quote Originally Posted by needsajet View Post
    Lol, jet! The pool is only 5.6' deep in the middle and the scuppers jut out a good 8-12" from the wall, so not going to encourage jumping from there. Jumping from the tanning ledge would be fine though. Doubtful on the mid air kiss...I'm quite the klutz.
    Quote Originally Posted by Marlahoutex View Post
    Thanks, Marla!! I'm going to be up and out there BRIGHT AND EARLY to make sure that happens!
    Denise-TFP Guide
