Thread: CYA on Taylor 2006
    Jun 2016
    Bayville,nj
    1
    CYA on Taylor 2006
    So I tested my water with my new 2006 test kit and my CYA is off the charts. The black dot dissapeared when the water level in the small comparator tube was only at 1.8 oz mark. That is far below the level for 100 ppm of CYA. Am I pretty much limited to emptying most of my water and refilling? The rest of my numbers are as follows:
    FC: 13.6
    CC: 1.2
    PH: 7.2
    TA: 110
    CH: 30
    CYA: off the charts
    38,354
    Re: CYA on Taylor 2006
    There is a diluted CYA test you can do to get a rough estimate of how high your CYA really is. But, yes, pretty much the only option is water replacement.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,262
    Welcome to TFP! Good to have you here
    For the diluted test, see #9 in: Pool School - CYA
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
