Thread: New Pool Install, Trying to install skimmer
    Jun 2016
    New Brunswick, Canada
    31
    So I've just put up my 21' above ground pool. The pool itself was used and came with everything, I've picked up a new liner and skimmer gasket. However now that the pool is installed, liner in place I only have a few inches of water in there now as I still need to work out some wrinkles before I start filling it more.
    I started doing some research on how to install the skimmer and return pipe (Going to wait to install skimmer and return until about 2/3rds of water is in). My question is in regards to the skimmer and the gasket, its a 12" wide Hayward one, the gasket I ordered/received its this white looking rubbery thing thats attached in the middle so almost like two flaps (I think the pool guys refer to them as butterfly gaskets).
    Now looking online my question is, this the right gasket for my pool and skimmer? Is there no other gasket that sites against the skimmer faceplate and liner itself?
    It appears to me that this gasket simply goes against the metal and that's it?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New Pool Install, Trying to install skimmer
    that is the exact gasket you need...
    on the outside the gasket will be on the metal
    on the inside the gasket goes over the liner and sandwiches the liner to the metal side then the skimmer gets screwed together..
    Jun 2016
    31
    Quote Originally Posted by cowboycasey View Post
    Cowboycasey; thanks for the reply. Then my next question is, how do I get this gasket to install properly so it actually sandwiches the liner on the inside to the wall?
    I was under the impression the gasket is basically only against the metal wall and then the liner presses against it and the skimmer faceplate. If it has to sandwich the liner against the wall I'm not sure how one would cut the hole for this?
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    Installing according to directions, it's not possible to sandwich both the wall and liner with the gasket, because cutting the liner is the final step. All the screws are in and tight before the liner is cut.
    https://www.hayward-pool.com/pdf/man...r-SP1091LX.pdf
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    Jun 2016
    31
    Quote Originally Posted by dsmith99 View Post
    Thanks! That's kind of what I thought as well! So basically I put the gasket on from the outside, then go in the pool and line the faceplate up against it and cut mount the skimmer and then trace the square hole out.
    This pool is somewhat coming together - its being filled as we speak.
    Now I just hope I can figure out the previous owners heat pump and filter hooks up below the deck...
