Thread: OK, site prep is pretty much done (pic); Do I need a gorilla mat?
    May 2016
    Seattle WA
    15
    Can I just use the included ground cover under the pool, or would the gorilla mat be worth the extra protection?
    Thanks!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: OK, site prep is pretty much done (pic); Do I need a gorilla mat?
    I think you would need something to help keep the liner from rubbing on the concrete and causing a leak. Do you think the pad you have will be enough? I am betting kids will be in the pool. Kids=lots of movement.........it is up to you but you want it to last for a while.
    Kim
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,833
    Definitely put something between the pool and the concrete. Adding the extra layer of protection is probably worth it.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    I put mine on paver patio. Last year was my first and while I had a gorilla pad, I tried to cut it too precise and ended up with part of the liner exposed to the cement. I had MULTIPLE tiny holes that I was patching all year. This year, I added a full size gorilla pad along with the one I cut PLUS a tarp. I have had Zero problems this year.
    So yes, you need something or the cement can easily cause leaks.
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
