Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: I just don't know what to do!
    Aug 2015
    Cincinnati Ohio
    18
    Last year was my first year of pool ownership. Lucky I found this site before I found the pool store. Last year I closed my pool unsure if I was in the middle of a problem or not. Opened this year and immediately drained my pool 3/4 because my cya was off the charts. Balance everything, and maintain proper levels. Start in on weekend pool maintenance 3 weeks ago and notice my water isn't as crisp as it usually is. Test my water everything is in range but on the low side, rebalance, swim, cover back on. Next day same thing, only now I have "dust" on the bottom. I slammed my pool passed all three. Got a little carried away one night and raised my FC level to 17, the same night I passed all three. 4 days go by no dust water I'd crisp, I'm checking everyday. Chlorine drifts back down hits 8, dust is back. Start the slam all over again. I can't get rid of it and I'm starting to get upset. What do I do? My water looks great. Please help.
    FC 12
    CC .5
    TA 100
    PH ?
    CYA 30ish
    f18 ft 48 in deep, 7600 gallon, round above ground vinyl pool. Hayward pump, sand filter. First time pool owner. Proud owner of a brand new TF-100 test kit.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: I just don't know what to do!
    Have you tried adding DE to your sand filter and brushing? Brushing a lot?
    If your sure you passed SLAM, that would be my next step. Add DE to the sand filter. See this link. Pool School - Add DE to a Sand Filter
    But also, brush a lot to get that dust up and in the skimmers to the filter.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Aug 2014
    Northern IL
    4,615
    Feel the sides and bottom of the pool. Do they feel slimy at all?
    Aug 2015
    Cincinnati Ohio
    18
    I have been brushing, usually twice a day. I feel no slim or slickness.... just dust. I think there was more today than any other day.
    Aug 2014
    Northern IL
    4,615
    Do you have a vacuum?
    Aug 2015
    Cincinnati Ohio
    18
    Yes, I vacuum twice a week. This dust won't suck up. It only disappears when I brush, into a little cloud.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Have you tried adding DE to your sand filter?
    Aug 2015
    Cincinnati Ohio
    18
    No, I will but shouldn't my filter be able to filter this out?
    Jun 2014
    15,212
    Some other things to consider:
    - Are you using a skimmer sock in your pool side skimmer(s)?
    - If the white "dust" is dead algae carcass, the DE might grab the finer stuff getting past the sand. Sand filters are great, but some of the very fine particles can get through which is why the DE may help.
    - You mentioned the cover. Have you cleaned under the cover? If it had algae under it, it could be re-introducing contaminants to the water when you cover it.
    - Also, do you remove the cover long enough each day for the pool to breathe and expose the water to the sun for good oxidation?
    Aug 2015
    Cincinnati Ohio
    18
    I tried to clean the cover as best I could the first cover the first go round. Hate to admit that I sprinkled some bleach around then hosed it off. (Not very thorough) I am gonna add the de hopefully this week. And I will look for a skimmer sock while I'm at it. The cover comes off at least 5 days a week. I have 3 little ones. The oldest is part fish, sorry she just corrected me, mermaid. Lol . Her best friends pool filter went down, it's now a swamp.... could the girls have brought it back with their swimsuits?
    Jun 2014
    15,212
    Yes actually. If the organics were bad enough they can cross-contaminate. Also depends on how vulnerable your pool might have been at the time. Several factors come into play. Often times we advise folks to cleanse their swimwear and pool toys during a SLAM just in case. Either way, keep us posted and let us know if you need more assistance. Have a nice day.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I was having similar problems for a brief time. I found there was a small amount of residual algae left under my stairs. Once I fashioned up a towel on a Swifter handle to scrub it, my water got its sparkle back. My brush wouldn't reach, nor could I reach my hand in underneath them. I've been adding that rask into my regular brushing routine.
    Aug 2015
    Cincinnati Ohio
    18
    So my plan is
    -clean all swimwear and soak toys
    -remove ladder inspect, scrub, and clean area underneath
    -clean sand filter and add de
    - skimmer sock (can I use panty hose?)
    -clean solar cover more thoroughly
    -after I pass overnight test bump FC up to mustard level just in case.
    Jun 2014
    15,212
    Looks good. Yes, you can use panty hose. If you pass the 3 SLAM criteria, you may not need to do the MA level shock, but if you chose to do so, make sure to only do it for 24 hours from the time you passed the regular SLAM. Good luck!
    Aug 2015
    Cincinnati Ohio
    18
    I bet it is coming from the ladder, inside the ladder. I just had my kid give it a once over, there are holes drilled in the bottom so the water will weigh it down and I'm thinking, I'm gonna take it out tonight. I'm willing to bet that is where my problem is.
    Aug 2015
    Cincinnati Ohio
    18
    Can't believe it took me this long. Jeez. Lol
    Aug 2015
    Cincinnati Ohio
    18
    Well I found it inside the ladder. I taped the bottom hole and have it filled with bleach water and the top rungs soaking in a bleach water. Any suggestions as to how long I need to leave them soaking.
    Jun 2014
    15,212
    If you can't actually disassemble the ladder rungs, I would leave the entire thing out and soak those things in bleach as long as your pool is in SLAM mode. Do all you can to eliminate that safe-zone for algae in the future. Very common trouble spot. Good job.
    Aug 2015
    Cincinnati Ohio
    18
    I'm hoping I pass the oncl tomorrow night!!!! So relieved!
  20. Back To Top    #20
    Aug 2014
    Northern IL
    4,615
    Good luck!!!
