Results 1 to 10 of 10
Thread: Dead Algae Always There
    Jul 2016
    Maynard, MA
    2
    My pool AG 27 ft with sand filter is sparkling clear. But after running filter dead algae remain on bottom in clumps. I have tried vacuuming and vacuuming to waste but that does not solve problem. I changed sand, even changed to fine Zeosand but no dice. The algae seem to puff into smoke when I vacuum, and if you step on the algae it disappears. I tried experiment by vacuum to waste, getting pool to look clear, then ran a pump in pool circulating water but bypassing filter completely by keeping it shut off. After 30 minutes I shut off pump and again all the dead algae appeared on bottom. I also tried flocculent and skimmer socks ; nothing works. I have had this problem for seven years now and am about to give up and deal with it, but any suggestions?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Dead Algae Always There
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jul 2008
    Seacoast, NH
    253
    You have living algae.
    Think of it this way: The only way to get more dead algae after you removed it by vacuuming is for living algae to die.
    How are you chlorinating?
    I suggest Pool School (link above) and, assuming your CYA level is in acceptable range, then SLAMming (instructions in Pool School.)
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Oct 2014
    Beaumont, CA
    47
    If youve tried vacuuming to waste and algae is still there, then either you have live algae or it never got sucked in by your vacuum. You say it puffs into a cloud of smoke, check the suction of your vacuum.
    16x48 Summer Escapes Pro-Series Above Ground frame pool, 5000 gal, Intex sand filter - Looking for heating solutions for AGPs
    Jul 2016
    Saint Joseph, MO
    45
    Is it for sure algae? Couldn't it be pollen or other debris?
    Also, don't forget to rinse after backwashing, before switching to filter.
    CHAD
    24' Above Ground 46.5" deep, 13,147 gal
    Hayward E-Series 25GPM/m2
    Sand 200 lbs
    Hayward Power-Flo LX 1.5hp
    Taylor K2006
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I w I uld recommend bumping up FC and doing an overnight chlorine loss test, provided you have a quality test kit.
    Aug 2015
    Cincinnati Ohio
    18
    I'm having the same issue. Just realized 2 minutes ago, my ladder has holes drilled in it so the water will keep in weighted.... check anything and everything that is in your pool... lights ladders inside, outside and underneath. It is dead algae just gotta find where it's coming from.
    Jul 2016
    Maynard, MA
    2
    Not sure if it is dead algae or other fine debris. I captured some of the fine stuff in a skimmer sock and it is brownish green. I read somewhere on this site that dead algae is milky white/gray?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    It can be either. SLAM levels usually turn it white after a few days if there is a lot of it.
    Jul 2016
    Saint Joseph, MO
    45
    I have dime sized pockets of dark brown/green here and there in the mornings after everything settles. My pool also sits 20% shaded under giant pecan trees (and squirrels). I've always assumed it was pollen or other tree-related matter, but would like to know for sure.
    CHAD
    Sand 200 lbs
    Taylor K2006
