Results 1 to 8 of 8
Thread: muriatic acid
    May 2016
    la junta, colorado
    5
    muriatic acid
    how long before you can swim after adding muriatic acid
    above ground intex pool 16FT x 48 INCHES vinyl liner round 5060 gallons
    Hayward 13 " sand filter system 30 gpm multi - port valve zeosans filter media
    taylor k - 2006 kit
    bLEACH, bORAX, bAKING SODA KEM - TEK DICHLOR , MURIATIC ACID
    POOL BLASTER VACUUM
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: muriatic acid
    Assuming this was a dose to just lower PH, I'd let it mix with the pump running for about 15 minutes or so. Maybe help it mix by brushing then test PH again. If in range, swim.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    May 2016
    la junta, colorado
    5
    Re: muriatic acid
    yes the pump was running
    taylor k - 2006 kit
    POOL BLASTER VACUUM
    May 2016
    la junta, colorado
    5
    Re: muriatic acid
    also I ran out of cyanuric acid for my cya test were can I get them for cheap for my taylor kit
    taylor k - 2006 kit
    POOL BLASTER VACUUM
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: muriatic acid
    Are you referring to the R-0013 reagent?
    May 2016
    la junta, colorado
    5
    Re: muriatic acid
    yes it is
    taylor k - 2006 kit
    POOL BLASTER VACUUM
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: muriatic acid
    I order my refills from tftestkits.net
    May 2016
    la junta, colorado
    5
    Re: muriatic acid
    thanks.
    and also here's my reading's from today
    here's my reading for today
    fc 5.4 ppm
    cc 6 ppm
    ph 7.4 ppm
    total alkalinity 100 ppm
    calcium hardness 100 ppm
    do these look ok
    taylor k - 2006 kit
    POOL BLASTER VACUUM
