Thread: Filter Tank Leaking
    Jul 2016
    Delafield, WI
    2
    Filter Tank Leaking
    I have a Sta-Rite Hi-Rate Sand Filter, Model T 240 BP-1. It is no longer manufactured. The tank is leaking on the seam at the collar. I've tried AquaMend epoxy putty inside and out. It seems to be holding on the inside of the tank. But, on the outside of the tank, the water pressure is too strong and it leaks through the epoxy. Any ideas about how to repair the tank without purchasing a whole new filter system? Thanks.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Filter Tank Leaking
    Do you have salt in your swimming pool? in that case you may have to use a glue or epoxy for marine use...
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jul 2016
    Delafield, WI
    2
    Sorry, my signature was not complete when I posted the issue. Its fresh water and the epoxy putty that is made for underwater use cannot adhere strongly enough to the outside of the filter tank to hold back the pressure of the water.
    2002 in ground, fresh water, 20 x 40, 3.5 to 8.0 feet deep, approximately 36,000 gallons, vinyl liner (2012), Sta-Rite sand filter (2002), Sta-Rite Intellipro variable speed pump (2015), Pentair 1.1 hp booster pump (2015), Polaris vacuum (2002).
    Pool: A hole full of water where the owner throws money.
    30,421
    The tank vessel "flexes" when under pressure so no repair will typically work. I think you should consider a new filter.
    22,550
    Adding to what Dave said, Since it's a pressure vessel, repairs to the vessel aren't recommended.
    Also those tanks are usually rotomolded and the plastics used aren't conducive to adhesives (they won't stick to it).
