Results 1 to 9 of 9
Thread: R0870 Dipper crusty
    Jul 2016
    Saint Joseph, MO
    45
    R0870 Dipper crusty
    How do you maintain the Dipper? Use it crusty? Rinse and dry each test? Use Dipper to stir (making it extra crusty)?
    There must be moisture in the kit box from testing because I have kept the Dipper dry, but it's all crusted up. Seems like results will not be consistent.
    CHAD
    24' Above Ground 46.5" deep, 13,147 gal
    Hayward E-Series 25GPM/m2
    Sand 200 lbs
    Hayward Power-Flo LX 1.5hp
    Taylor K2006
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Re: R0870 Dipper crusty
    Quote Originally Posted by seedlings View Post
    CHAD
    You can use it crusty like I do. The exact amount of the powder isn't as important as having enough of the powder. But, you can clean that dipper up with MA diluted in water.....the thing is I don't recall the ratio of MA to water.?
    Found it. Two parts water, one part MA
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    If I recall correctly, one to two
    http://www.troublefreepool.com/threads/121845-Spoon
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Quote Originally Posted by Piolin View Post
    I think it was your thread that I went back to to find it. Dave said 2 waters 1MA. Different wording than mine. And while I wont reccomend it, I think a couple of years ago I soaked the bottom of my dipper in straight MA.
    Jul 2016
    Saint Joseph, MO
    45
    Ok, now i'm wiping it with a paper towel right after use.
    CHAD
    Sand 200 lbs
    Taylor K2006
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    JoyfulNoise's Avatar
    May 2015
    13,254
    R0870 Dipper crusty
    I scoop the powder with the dipper and then on the second scoop I immerse the dipper in the vial and let the SpeedStir rinse off the powder. I then take the dipper to the sink and rinse it off under running water and dry it with a paper towel. I never let old powder crust up on it. My dippers are always clean between uses.
    Matt
    domct203's Avatar
    Jun 2015
    CT
    3,596
    I rinse and dry my dipper after each use as well. I'm on my second season with this one and it looks brand new.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Quote Originally Posted by domct203 View Post
    Dom
    Ok......you rinse and dry people are making me feel bad for my crusty spoon. Nonetheless, when it get crusty, MA will clean it up but mine is also 4+ years old. Stayed clean for quite a while.
