Thread: Solar Reel ?
    May 2009
    Kentucky
    9
    Solar Reel ?
    I have searched, but I still have not seen an answer to which solar reel seems to be the best option. So I thought I would ask to get some current opinons I'm looking at the low profile rocky but the $$ seem high and I'm afraid no matter which one I get I will need a new one in 4 to 5 years. I like to using my solar blanket this time of year but once the summer gets going here in KY the nights stay in the low 80 so in july I usaly store it until late August. After reading on the forums it sounds like there is some benifit to keeping the cover on the entire season so I would spend some extra $ for a better reel that I can leave under the diving board, but I like to get the most bang for the buck, any suggestion?
    Location = Central Kentucky
    Pool Size = 18x36 - 8ft deep end
    Pool Type= Inground Vinyl
    Filter = Hayward PRO Series Sand Filter
    Pump = Hayward Super Pump 1.5 HP
    Test Kit = TF-100
    Re: Solar Reel ?
    I just purchased and received the "Deluxe" reel from Inyo Pools online. Paid $214 with shipping. Easy to put together (just need power drill, 1/2" bit, 5/32" bit and 7/16" nut driver.) and so far it seems to be well built for the money. It even came with the "optional" caster set so I can wheel it around the pool if need be. With casters folded its a mere 17" high and should tuck under your diving board.
    13,100 gal (?) IG Plaster Pool, Rectangular (30 feet long, 11 feet wide at 3 feet deep shallow end, 14 feet wide at 6 feet deep end.)
    Pentair Challenger 1hp 2 speed hardwired pump
    Triton II T60 sand filter
    P153 Intermatic digital timer control
    8 gal Liquidator with 3/8" upgrade
    Mar 2008
    Harrisburg, PA
    13
    Re: Solar Reel ?
    Try to get one with metal ball bearings, not the cheap wooden ones. It's too hard to turn and the wood breaks apart.
    Harrisburg, PA
    18 x 38 IG Gunite/plaster pool
    Oasis form 18,500 gal
    Jandy Aquapure SWG
    Mar 2007
    Morris, IL
    477
    Re: Solar Reel ?
    Somebody on here has a home made one. One of the mods I believe.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Jul 2009
    Prairie Du Chien, Wi (SW Wisconsin)
    24
    Re: Solar Reel ?
    I had a 18 x 36 inground from '89-'97 and bought a Fehergard reel with large white wheels that rolled it anywhere, no sag, had to use chocks that came with it to lift the wheels onto to keep it from rolling. Loved it and wish they made one for my 22 x 44 inground.
    I bought a "professional" grade reel for my current pool that was guaranteed not to sag from IN The Swim. It is on its 3rd year and sags almost to the ground. The cover bunches up in the middle and it takes 2 people to reel it up as we have to keep tugging on the edge of the cover to take out the bunching as we reel it up.
    I called the reel company and they sent me 2 longer inside pieces that span the joints. The tubing comes in 5 pieces with 2 of them spanning the joints of the 3 outside ones. Would not buy it again.
    I miss the Fehergard, but my pool is wider and longer so the cover certainly weighs more now. Maybe nothing out there will handle a 22' x 44' solar cover.
    56,000 gal in-ground vinyl liner, 22' x 44' with 10' deep dive well (only 8' long shallow end)
    1 hp Hayward Superpump, runs 24/7, 300# Hayward S244T sand filter
    Hayward H300 300,000 BTU LP gas heater, Rainbow auto chlorinator w/ check valve
    Liquidator liquid chlorine feeder, Polaris 380 pool cleaner with 3/4 hp booster pump
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Re: Solar Reel ?
    We got this one. This is our 5th or 6th year with it and no sag. I'm not sure it would fit under your diving board though.
    http://waterwarehouse.com/poolsupplies/ ... -Reel.html
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
