Thread: How to fix leak at seam of plaster and coping
    Jun 2014
    Austin, TX
    17
    My elevated spa is leaking at the joint between the plaster and the coping. How do I make this seam watertight? The pool builder mason came out and attempted to apply some sort of white material at the joint, which does not look good, but did not fix the leak. They do not appear to know how to fix it.
    When I fill the spa, water starts to slowly pour through and across the rocks on the outside of the spa as soon as the water gets above the plaster/coping joint. Fortunately, the water leaks into the pool. However, I would like to maintain the water at the top of the coping level without having to spill over all the time (lots of unneeded evaporation, etc).
    IG Pool Size: 24,000 gallons
    Flagstone Decking, Pebble Plaster
    Cartridge Filter
    Date of pool build October 2014
    Spa , SWG
    Apr 2015
    tucson, arizona
    1,128
    Re: How to fix leak at seam of plaster and coping
    I have had great results using sikaflex sealant. You may have to open that crack up and thoroughly clean out. There are many colors available but not sure what you can find locally.
    May 2017
    Denver, NC
    1
    Hi there, I was wondering if you solved your issue and what product(s) you might have used. I have having a similar issue with a spillover in my tanning ledge.
    Thanks!
