Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: my lastest numbers
    May 2009
    Trenton NJ
    497
    chlorine?
    fc-1
    tc-5
    cc-4
    ph-7.6
    ta-120
    cal. hard-100
    cya-30
    The guy at the pool store said I am in a chlorine lock(whatever that means) and I need to shock my pool with 12 lbs of supercharge.
    I been shocking with bleach for two days. Last night I added 10 ounces of trichlor and my readings were as posted.
    Do I need to lower ph with acid or just shock for now, and if so how much bleach do you recommend?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    May 2009
    Trenton NJ
    497
    Re: chlorine?
    By the way I have a 20,000 gallon fiberglass pool.
    May 2009
    Trenton NJ
    497
    Re: chlorine?
    one more thing I have a swg.
    30,401
    Re: chlorine?
    ethany,
    Welcome to the forum.
    How does your water look? Are you having a problem?
    Guest
    Re: chlorine?
    Your CYA is way too low for a SWG. READ THE MANUAL that came with it and you will see! THis thread might help you
    water-balance-tips-for-a-swg-t3663.html
    after you read the pool school section of the forum so you understand it (link to pool school is in the upper right corner of every page--read EVERYTHING in it twice!)
    Chlorine lock is a nonsense word! Your chlorine is getting consumed by a nascent algae bloom because your FC is burning off in the sun because your CYA is too low! This is why you have so much CC and very little FC. You need to start shocking the pool with bleach or liquid chlorine to 20 ppm and KEEP IT THERE until there is no CC on testing (if you don't understand what these terms are you NEED to go to pool school and learn and learn how to take control of your water!. That is what we are about here. You are not alone, we are here with you evey step of the way and we are not trying to sell you a lot of chemicals in the process!)
    Jan 2009
    Cupertino, CA
    1,966
    Re: chlorine?
    If you describe your pool and gear in your signature, you don't have to keep posting it.
    Besides what waterbear said, trichlor adds CYA as well as FC but it typically dissolves very slowly so it's useless for shocking. You're better off with liquid chlorine or bleach (the same stuff at different concentrations) for shocking, and get some CYA to add. It can take a week to dissolve so do that right away too.
    Shock FC levels are related to CYA, see this Pool School article.
    --paulr
    BBB "Intermediate Swimmer"
    May 2009
    Trenton NJ
    497
    Re: chlorine?
    So the first thing I need to do besides pool school is shock with bleach? Also about how much would get me to 20 ppm.
    When should I use the stablizer? The water looks alot better today than yesterday,its not as green, mostly cloudy. I can see bottom in low end but not in the deep.
    What a great site this is I wish I found it along time ago.
    Guest
    Re: chlorine?
    Read pool school! It should answer just about all your questions. When you are done post questions about any points you don't understand! The pool calculator (link in my sig) will tell you how much bleach to add AFTER you have read pool school. It should only take you about an hour to read it all twice.
    Get the stabilizer in now to bring your level up to about 70-80ppm. What SWG do you have and what is your salt level?
    Your TA is also a bit on the high side but don't worry about that yet.
    Jan 2009
    Cupertino, CA
    1,966
    Re: chlorine?
    Use the Pool Calculator to figure out how much bleach to add. It depends on what kind of bleach you buy, meaning the % of sodium hypochlorite, which should be on the label. Typically household bleach is 5% or 6%, you can get "liquid chlorine" at many pool stores or home-depot type places at 10% or 12.5%.
    --paulr
    May 2009
    Trenton NJ
    497
    my lastest numbers
    Threads merged for consistency. Moderator.
    tc-0
    fc-0
    ph-7.4
    ta-100
    ch-160
    cya-40
    I have a swg so I assume I need a higher cya number. The person at the pool store was trying to sell me a phosphate remover,he said that is the reason I am not keeping chlorine in my pool. I told him I will keep shocking it. I throw in about 2lbs of balancer 48hrs ago. I been shocking my pool since sat. according to pool calculations and still no chlorine. Any suggestions?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: my lastest numbers
    What is 2 lbs of balancer? Do you mean stabilizer to bring your CYA up?
    You aren't keeping your pool at shock level. IF you were, you'd have a FC result. What are you shocking with, where did you buy it?
    Shocking means keeping the FC up at shock level and holding it there, with frequent bleach additions. We can only assume based on your results posted that you haven't been following the instructions, or there is something wrong with your bleach.
    May 2009
    Trenton NJ
    497
    Sorry i meant to say stabilizer.
    I use 6% bleach to shock according to pool calculations. In fact I doubled the amount of bleach it called for and put it in tonight. The water looks cloudy,not green like before.
    11,969
    Quote Originally Posted by ethany
    What brand of bleach/where did you buy?
    May 2009
    Trenton NJ
    497
    I purchased it at BJ'S its chlorix bleach 6%. 182 oz bottles. I put two in tonight. Been using 1 bottle 2x a day since sat.
    11,969
    To raise your FC to 15 (your shock level for CYA of 40) you need 3.4 jugs of 6% bleach, 182 oz size. So 2 jugs tonight aren't enough.
    When shocking, frequent testing and bleach additions are key. If you can only do it in the evening, you need to test, go to the Pool Calculator, enter your pool size, enter your FC result in the "now" column, enter 15 in the "target" column, hit calculate and then it tells you how much bleach you need.
    It sounds like you just haven't been adding enough. If you aren't calculating based on the current FC levels, and then determining the proper amount, you've probably been coming up short every time.
    30,401
    ethany,
    you're getting there but, like FPM is saying, you are not dosing heavily enough. Be very accurate with your dosing and testing and your pool will clear quickly.
    May 2009
    Trenton NJ
    497
    How do you come up with the number 15 for fc
    30,401
    Chlorine/CYA Chart up in Pool School
    11,969
    The Recommended Shock level from the pool Calculator - it's based on your current CYA level. As your CYA level increases, so does your required FC/shock levels - refer to the chart. 15-16 for now, but when your CYA goes up that level will be higher.
  20. Back To Top    #20
    May 2009
    Trenton NJ
    497
    How do my numbers look other than chlorine? Since I have a swg does my stabilizer need to be higher? How about my CH is that too low?
