Thread: Easy Pool Float Rack
    DeanG's Avatar
    Jul 2013
    Friendswood (Houston) / TX
    27
    Lightbulb Easy Pool Float Rack
    Everybody has this problem.. pool floats either scattered around the deck, or piled up in a corner. They get dirty and collect leaves/debris.
    I came up with this after seeing that FB post about PVC pipe being used to make a towel rack.
    Total cost was less than $50 in PVC pipe & joints. Took 3 trips to Lowes, but what project doesn't??
    It's 1.5" PVC for the frame and all the uprights. The joints are all simple T fixtures. There are caps on all the pipe ends, including the feet keep dirt and water out.
    The joints/caps fit tight, so everything is put together without glued/cement. This way it can be taken apart for storage at the end of the pool season.
    The double horizontal bars on the bottom make it very sturdy. The uprights are 8" apart for floats.
    The design is pretty adaptable. It can be made bigger/smaller by adjusting the lengths/numbers of pipe.
    Hope somebody finds it useful!
    Dean
    16K In-ground, Free-form 16'x30', 3.5'/6'/4', Gunite, Original Build ~1996, Renovation 2016 (Wet Edge Luna Quartz (Aruba) & Travertine Coping), Pentair Globrite LED light w/ Intellibright Controller, 1 Hayward Skimmer, Pentair SuperFlo VS Pump, Hayward Aquarite AQR15 Controller & T-15 SWG Cell, Hayward Sand Filter w/ Variflow XL Multiport Valve, Pentiar MasterTemp 400K BTU Heater, Kreepy Krauly Cleaner, TF-100 Test Kit (w/Speed Stir)
    Jul 2015
    Central Valley CA
    1,107
    Re: Easy Pool Float Rack
    Got to love PVC! Did you track the cots?
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    DeanG's Avatar
    Jul 2013
    27
    Quote Originally Posted by atttech-2 View Post
    Just went and measured.
    Long horizontal base piece - 38"
    short horizontal base piece - 24"
    tall risers - 36"
    short risers - 24"
    The legs are T junctions butted together with a 1.5" piece connector.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Looks nice
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    Jul 2013
    Waxahachie, Tx.
    442
    I like it. Good job
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
