Pool Store vs. TFTestkit - testing the testers
viking68
0
69
Lake Mary, FL
Had to pick up some chlorine yesterday, so I tested the testers.
They had just tested someone else's water - no rinsing of test tubes - just "dump 'em and on to the next" (me).
I had tested just before leaving home - store is 1 mile away - same EXACT water sample:
TFTestkits Pool Store
Cl - 9.5 5.0 (they don't/won't do a drop test) (am coming down from a SLAM)
pH - 7.5 8.0
TA - 80 120
CH - 300 380
CYA - 40 40 (yeah - they got ONE right!)
So, if anybody needed any more proof of how our method works - here's a classic example. My water is sparkly crystal clear.
Of course, they offered to check for phosphates (declined) and did give me a TDS of 1600 - because, well, it's important --- NOT!
On a side note, my chlorine was being eaten up a a pretty prodigious rate - 2-3ppm/24 hours a week ago. Discovered the culprit - dang Polaris Bag! Pulled it out and soaked in chlorine for 24 hours - now the ONCLT - less than .5 ppm overnight with .75" of rain! Happy camper.
Have a great Sunday everyone!
I finally have time tomorrow to go return the stuff they sold me over winter on their "special" sale days...
I am not even bringing water to test... Don't want to bother anymore as I know the numbers will be wrong. I would bet 100 bucks my TA with them will be 40 or 50 so they will try to sell me expensive baking soda.
I will just say, half the season is over... I haven't needed any of this, Id like to return it. Should be 200 or 250 back
See what they say, and do...
Thanks for the side by side compare, Viking! I've been wanting to do that myself for a while. But I REALLY don't want to go to the pool store... :)
Only reason I do (go to pool store) is because it's FL and there are several stores within a couple miles of my house. 12.5 chlorine is literally available cheaper @ pool stores than anywhere else - just saw 3 gallon pack of Clorox @ BJ's for 9.91. Ridiculous. I pay $4 for 2.5 gallons. Sure, I had to pay the "deposit" on the jugs, but that was so long ago I cannot even remember how much that was - years.
Oh man, light bulb moment! I really should empty that Polaris bag, I bet that is where a lot of the chlorine loss is going!
Not only empty it, soak it like I did - full strength chlorine. So what if it shortens bag life; should replace is once a year anyhoo.
After monitoring the pool since, I know that's where the little buggers were hiding - killed 'em dead!
I just used Pool Math to determine that 1/2 tsp of 10% liquid chlorine in 1 gallon of water would give you 30ppm chlorine. That should be more than enough to get rid of anything living in there, and be quite a bit more gentle on your equipment bag.
Just a thought.
Just a thought.
I did the Pool Math for 1 gal pool size and added 1 oz. 10% bleach; result was FC 781; divide it by 12 (1oz = 2 Tablespoons = 6 teaspoons = 12 one half teaspoons) = 65 ppm. So for 32 ppm in 1 gal water, it only needs 1/4 teaspoon 10% chlorine unless I am calculating it wrong.
