Thread: Slippery fiberglass pool
    Jul 2016
    Pearland TX
    35
    Hey pool experts....
    New fiberglass pool owner here. Ever since we put pool in( about two months ago), it has been extremely slick, causing people to slip especially on the stairs.. I have been faithfully treating my pool and taking water to be checked to verify my home kit is accurate. ( ok been reading...need a BETTER home kit...wow so much to learn...will be ordering TF 100 asap)
    My levels are within the ranges etc. I don't have exact numbers off hand as I am work right now. Its a 14000 fiberglass pool, SWG, with a variable speed pump.
    Water is crystal clear and beautiful!!!! Always has been. I am getting frustrated since we called the company who installed and stated we must have a water problem. They stated they had this once or twice before and gave me a number of a pool cleaning company who could test the water for even more things. Problem is nearest store is 45 minutes plus away.
    Anyone have any ideas or what could be causing this?? What else should i be testing for?
    Thanks in advance
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Slippery fiberglass pool
    I have a fiberglass pool. It's not new though. One thing I've noticed with mine is there is a rough texture on my steps and seating area. Does yours have that?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2014
    14,970
    Hello and welcome to TFP! We experienced the exact same thing as you for the first couple months. That was before TFP for me and just before the green began to show. l The slipperiness is not good. You do need a TF-100 ASAP because I suspect that's the calm before the storm. In the meantime, make sure to only use regular liquid bleach as your sanitizer to increase FC. In my pool just under 18K, that's about 1/2 gallon of HEB's Bravo regular bleach each evening. For you it should be a little less. But your pool walls and floor should not be slippery/slimy at all. They should feel clean and your feet should feel stable. We busted our rears a few times on our slippery steps before TFP.
    Once you get your test kit, make sure to post a full set of test results.
    Also, please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. Or you can click EDIT YOUR SIGNATURE. It will help us later. This link may also help you: Pool School - Read This BEFORE You Post. Nice to have you with us!
    Jul 2016
    Pearland TX
    35
    Thank you for confirming I am not insane and going to have to live with a slippery pool for ever. My walls and bottom and stairs are all slippery. YIKES. Will be getting bleach as soon as I get off of work. I will add more information to my signature too but don't have it all since I am at work.
    I am so happy to have found this group. And am learning so much so quickly.
    Thanks for the support.
    Will keep you posted as i make progress.
    ANy other tips greatly appreciated!!!!
    15000 fiberglass Viking free form pool, swg, Hayward variable speed pump cartridge filter
    TF 100 kit.
    Jul 2016
    Pearland TX
    35
    yes it does but right now even that is slippery...
    TF 100 kit.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Oh oh! Like Texas Splash said, sounds like the start of algae
