Results 1 to 20 of 20
Thread: Noisy pump
    Sep 2015
    Smithtown, NY
    46
    Noisy pump
    I recently vacuumed my pool and during the process, my ordinarily quiet pump took on a minor yet annoying rattling noise. I've backwashed and rinsed several times to no avail. Now this rattle is constant and i'm hoping someone can aid me in returning my pump to its former glory. Thanks.
    Constructed November 2015, concrete walls, 29,000 gallon capactiy, vinyl liner, Max-Flo VS filter pump, Hayward DE4820 Filter, Aquarite Salt Water Generator, TF-100 Test Kit.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Noisy pump
    Hard to say without hearing it. Can you post a video of the noise?
    If it is a rattle (not bearings or cavitation), there might be something stuck in the wet end. The manual should tell you how to remove the motor so you can get to the impeller area.
    Mark
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Noisy pump
    It might be the bearing going, are you able to turn the shaft by hand, does it turn smoothly? Is the shaft seal leaking? Is the impeller on tightly? If it's a bearing change is about $20 and about an hour of time. Do a check on youtube for pool pump bearing replacement. The job isn't too difficult.
    Sep 2015
    Smithtown, NY
    46
    Re: Noisy pump
    Quote Originally Posted by mas985 View Post
    I'm unable to attach the video to this past for some reason, but I will check the manual. Thanks.
    Sep 2015
    Smithtown, NY
    46
    Re: Noisy pump
    Quote Originally Posted by bobodaclown View Post
    This is my first season with the pool, do you think a bearing could already be falling? Not sure what an impeller is, but I will look it up. The valve handle is exceedingly difficult to manuveur between filter, backwash, rinse, etc. I have to put my full weight behind it. Though after rinsing a few times it did become a bit easier. No leaks.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Noisy pump
    Post the video to youtube and then post the link here.
    Mark
    Sep 2015
    Smithtown, NY
    46
    Re: Noisy pump
    Ok I will thanks
    Sep 2015
    Smithtown, NY
    46
    Re: Noisy pump
    July 10, 2016 - YouTube
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Noisy pump
    Doesn't sound like bearings. I would open the wet end and see if anything is stuck in there. But check the impeller inlet first under the pump basket to see if there is anything stuck in there.
    Mark
    Sep 2015
    Smithtown, NY
    46
    Re: Noisy pump
    Pardon my ignorance but what is the wet end?
    Jun 2016
    Martinez, CA
    207
    Re: Noisy pump
    If you attached a vaccum hose and head attachment you likely are getting suction cavitation from the additional restriction. Mine did this until i drilled a hole in the hose connection that goes into the skimmer basket to lessen the vacuum. After that, it worked fine.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Noisy pump
    There are two parts to a pump, the wet end, the part that has pipes connected to it, and the motor which sticks out the back end with electricity connected to it. At the end of the motor shaft is the impeller. This is what moves the water and on occasion get clogged with debris. You can reach the impeller inlet through the pump basket housing but that does not always clear the debris. Sometimes you have to open up the pump (separate the pump from the motor) and visually inspect the impeller.
    You can see all the parts below. #10 is the impeller. Parts 1-13 are considered the wet end.
    Mark
    Sep 2015
    Smithtown, NY
    46
    Re: Noisy pump
    Thank you for taking the time to post and help me out with this issue. I will investigate.
    Sep 2015
    Smithtown, NY
    46
    Re: Noisy pump
    I removed the basket and couldn't find anything jammed on either side of the basket. Looks like I'll need to get to the impeller. Hopefully it won't be too complex of a process. I'll report back.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Noisy pump
    Did you reach into the impeller inlet at the bottom of the pump basket?
    Mark
    Sep 2015
    Smithtown, NY
    46
    Re: Noisy pump
    Yeah I jammed my fingers way deep in there and didn't feel anything unusual.
    Sep 2015
    Smithtown, NY
    46
    Re: Noisy pump
    Do you think I should maybe swab a brush around deep into the impeller before going through the trouble of breaking the pump down?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Noisy pump
    Usually, if you can't feel anything, it is probably clear in the inlet. However, you need to take apart the pump to check the impeller vanes. That is the only way to reach them.
    Mark
    Sep 2015
    Smithtown, NY
    46
    Re: Noisy pump
    Well, I took apart the pump but was unable to remove part 10 from part 14. I was able to more closely inspect the impeller but was unable to remove the impeller itself to see if there was anything lodged behind it. I decided to put everything back together again and hope for the best, and sure enough somehow that did the trick. The rattle noise is gone and the pump is working smoothly with no leaks. I greatly appreciate your assistance and if you ever find yourself on Long Island, I owe you a beer!
  20. Back To Top    #20
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Noisy pump
    You shouldn't need to remove the impeller. You just need to look inside the vanes. Probably something fell out when you opened it up.
    Mark
