Results 1 to 11 of 11
Thread: Screen Enclosure For Pool
    Apr 2009
    Orange Park, FL
    104
    Want to have a screen enclosure built for our pool. Live in Florida and would appreciate any advice on what to look for and ask contractors as they visit and quote?
    15x30 IG vinyl liner pool, pool cage
    Hayward S-220T high rate sand filter and Hayward super pump w/1hp motor
    Hayward SwimPure Plus SWG
    Polaris 380 cleaner and booster pump
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: Screen Enclosure For Pool
    I would suggest that you do some research and decide what you want built before you have contractors start bidding. You need to specify the dimensions, shape, material of construction, how it's anchored, and the number and size of doors. The frame and type of screen will impact the cost a great deal and you should decide what you want. Another important item is the design wind load - is it going to just set on the ground and get blown over the first time the wind gets to 25 mph or is it going to withstand hurricane force winds?
    This is one of those projects where a visit to a Civil Engineer could end up saving you a lot of money and a lot of grief down the road. It would not take a good Civil Engineer very long to draw up a layout and write a set of specifications that would let you know what you are getting before it's built, and I don't think it would be very expensive.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    no-mas's Avatar
    Jun 2008
    FL
    405
    jagfan, are you looking for a typical Florida pool enclosure? Seems like every contractor I spoke to offered the same type of structure - aluminum frame engineered to 130mph winds per FL building code, and in Duval county, needed permitting and inspections... however, I don't know about Clay county. Anyway, I've never seen another kind of enclosure - maybe I need to get out more...
    Yes, know what you want in terms of size and shape, but I've never seen anything besides what I've described above. We went with Stanley Pools and Screens, who did a great job for us. Look for their sign as you cross the Buckman.... but ultimately, be sure you use someone licensed and experienced. I don't need to tell you, there are many good ones around (and some not so good.)
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Apr 2009
    Orange Park, FL
    104
    Jmas65
    That is exactly what I'm looking for. Sorry I really didn't better describe it. I'm in Doctor's Inlet/OP and am familiar with Stanley Pools. Glad to know they do good work. I may give them a call. So far I have two proposals, getting another tomorrow morning. Are you familiar with ScreenWorks on Blanding Blvd? They designed a nice enclosure and are the front runners so far.
    no-mas's Avatar
    Jun 2008
    FL
    405
    No, I don't know screen works - which doesn't mean they wouldn't do a great job. Look at some of their other jobs and go with your gut. Whoever you choose, though, do make sure that they are licensed and will build to code.
    Hey No-Mas,
    Go Gators! By The Way.
    Do you remember how much it cost to do your screen enclosure? I want to do one for the pool here in Lithonia, GA (Greater Atlanta area), but I have not found any reliable contractors in the area, so I was thinking of getting the handy folks in the family together for a big DIY.
    From your experience with your own enclosure is it possible that this could be a DIY Project?
    I am from Florida myself, and one thing I noticed up here was that no one really did the pool screen enclosures, when I called the local building places, they did not even know what an extruded aluminum frame was
    Pool Size - Trying to figure that out. SBMW 2000 (2048 Model) Inground Pool.
    30,403
    Hey, Manasia,
    You've moved too far north for an enclosure. Ice and snow will quickly bring it to the ground
    no-mas's Avatar
    Jun 2008
    FL
    405
    ...Ice and snow will quickly bring it to the ground
    OMG - I'm so dense. I always wondered why there are so few of these things outside of Florida. Makes sense, Dave.
    Manasia, Go Gators! While the structure is engineered to withstand hurricane force winds, it is a given that the screens will blow out in a strong windstorm. Rescreening isn't a huge deal, but it's something that you don't want to do any more than you have to. I imagine it wouldn't take much snow/ice to cause the screens to give way. I wasn't on site when mine was built, so I wouldn't be a great judge of whether it is a diy job or not. I don't recall exactly how much my enclosure was, but will look it up if you're still interested.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,053
    jagfan, call Doug Hill at 904-891-6324 or contact at enclosureman@comcast.net
    Use me as a referral. He is the best and very competetive. We used him after getting many quotes. Look at our pool build in the sig bar.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Thanx Duraleigh. I did not look at like that. I saw someone with a screen porched but it was made with wood. I Think I am going to abandon the idea, I am not in Florida anymore.
    Hey no-mas do not worry about looking it up. I am just gonna go get some wooden picket fence, and surround the pool and call it a lifetime LOL.
    Jun 2016
    Atlanta, Georgia
    2
    Manasia,
    I live in the Atlanta area, and DC Enclosures in Marietta builds screen pool enclosures that withstand wind, snow, and sleet. I know this is a 2010 thread, but I had to add this to let others know.
