Thread: Pool Math - Effects of Adding Chemicals calc not same as Now/Target
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    First time using Pool Math. For PH entered my Now reading of 8.2 and my Goal is 7.8
    Says add 22oz of 31.45 muriatic acid.
    When I enter on bottom of page 22oz. says it will l lower PH by .35
    These don't agree but not by much.
    Are these rounding errors or am I doing something wrong?
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Pool Math - Effects of Adding Chemicals calc not same as Now/Target
    Looking at the number of decimal places, I would say that .35 and .4 are the almost the same thing... since that's what you get when you round up.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    JoyfulNoise's Avatar
    May 2015
    13,186
    Look at the warning note in the Effects section. It clearly says that the pH calculations are approximate because it has to make certain assumptions about other values in order to do the calculations.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Correct. PH is impacted by many factors, TA, borates, etc. The more info entered into Poolmath the more accurate the calculation.
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Thanks everyone. I thought it might be the rounding but didn't know about the other factors that can affect it. I haven't entered all of those yet.
    Tomorrow is my start-up day with the PB. Pool is filled with tap water.
    DFW, TX
    24,468
    Nice! Be sure to follow your installer's instructions, the mfg instructions and register your warranty, more here, Wet Edge | Warranty Wet Edge | Warranty. The first 30-60 days are important.
