Results 1 to 16 of 16
Thread: how long do you give it?
    Jun 2014
    Houston, Texas
    475
    We have been trying to maintain our FAC since 7/2.
    7/2 it was 3
    7/3 it was 2 and we added bleach because we needed to get it up quickly bc we were having a party
    7/4 it was 4 with bleach
    7/7 it was 2.5 and pH was 7.8. Turned the SWG to 40%
    yesterday the quick test said the chlorine was 5 (which I somehow doubt) - I have ordered more of the FAC stuff. So I have been using the quick test.
    today it was 2. (eeking out a tiny bit of powder from our test kit)
    A couple days ago it said check cell. we reset it and it seems fine. we never reset it after we turned it on after the plaster redo.
    how long do you give it to bring the chlorine up? we are trying to see if it's not working. it's hot here and my husband doesn't want to add bleach bc he says we won't know if the SWG is working or not. It's a Hayward SWG
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: how long do you give it?
    Is your salt level in the proper range? Has the cell been kept clean?
    Jun 2014
    Houston, Texas
    475
    yes and yes
    19k SW IG
    30,403
    What does your water look like now?
    Jun 2014
    Houston, Texas
    475
    water is beautiful - crystal clear. however, I do worry about algae and cleanliness. Also, we are going on vacation soon and I need to get this figured out
    19k SW IG
    30,403
    What percentage is your SWG set to?
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    How is your CYA?
    Actually it will be better if you can post a full set of results
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jun 2014
    Houston, Texas
    475
    FAC 2
    CH 325
    TA 80
    CYA 60
    pH 7.8
    Well, we've been going up and down - had it at 40 and the FAC was 7 and rising. Took down to 30, nothing. Took it to 32 and finally it went to 4. At one point it was 20. We keep thinking we've got it and bam. no, we don't.
    19k SW IG
    Jun 2011
    Long Beach, CA
    2,778
    Post the diagnostic readings with the SWG turned on at 100%. The results will tell us if it is making chlorine or not.
    Jul 2014
    Hope Mills, NC
    567
    It must be working, I would use bleach to gat to your target and after that dial in the %.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Jun 2014
    Houston, Texas
    475
    Quote Originally Posted by Griswald View Post
    that's the problem - can't get it to dial in. it's going up and down like a yo-yo
    19k SW IG
    Jul 2014
    Hope Mills, NC
    567
    Quote Originally Posted by DMS2014 View Post
    Yes, but you aren't starting out with a good, consistent quantity of free chlorine SWG's simply don't work well at going from a real low number but they are really good at keeping a number steady. Thats why I suggested that you get the correct value with some bleach and then let the SWG hold that value, not turn it up to 100% and then try to figure the correct number out by turning it back down.
    I'd suggest getting the FC up to whatever amount you require and then setting the SWG to 50%. Check it the next day. If it is much lower, add bleach (just like before) and try 75%. If it is holding or just slightly dropping, your good. If the number goes up, don't just turn it way down, lower it 10% at a time and let it go a day or two.
    Vinyl in-ground
    1 HP Pump
    Hayward SWG
    May 2015
    Land O Lakes, FL
    527
    What he said ^^
    Your CYA may be a little low as well. See the Pool School - Chlorine / CYA Chart
    What brand/model of cell do you have? See the following page for a calculator that will help determine the time required to run the SWG. Formula for SWG / Pump Runtime?
    It is recommended to use Pool Math and bleach to get your FC to at least the target level, higher is better. Something like (Target FC + Daily FC Loss + 1). Then you dial in your SWG until you know that it is able to replace the 24 Hr FC Demand. The idea is to keep your pool from going below the minimum while you dial in the % and run time.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Jun 2014
    Houston, Texas
    475
    Quote Originally Posted by ping View Post
    it's making chlorine. Did the test and it said 90. don't know what that means.
    It's up to 3 now but I don't consider that high enough for our weather. I added bleach today. I will check and see where we are again. My other tests I did last night are good - TA is 80, CYA is 80, pH is 7.6, CH is 350
    19k SW IG
    espejo's Avatar
    Nov 2014
    Kingwood Texas
    148
    My Pentair IC40 was bouncing around like that too until I raised my CYA to 80. It is much better now. Our pool is in full sun starting at 10am and stays that way until around 7-8pm. In addition, to full sun the Houston heat is brutal and that is likely a cause as well.
    40x15 IG, 19,000 gallons, Taylor K-2006C, Intellichlor IC40, Pentiar 1.5 hp Intelliflo VS, Pentair 420 Clean/Clear Filter, Speedstir, Stonescape - french grey, Travertine Paver decking, Completed August 1, 2015.
    Jun 2014
    Houston, Texas
    475
    yeah, My CYA is at 80 too. I will test it again tomorrow....sigh...
    19k SW IG
