Thread: SWG Saniclear 20 too much FC
    Aug 2015
    Blainville/QC
    10
    I have my saniclear 20 set at 5% currently and my FC vary between 4 and 5.
    I have had the water analysed and beside the FC everything is absolutely perfect.
    The pool is 13000 gallon.
    I feel like even if it says 5% it's generating at 100%
    Everytime I check the cell, the voltage and amp indicate it is currently generating.
    From my understanding, the % you set the SWG is the % of time of the day it is running.
    Any idea?
    The pump has variable speed and is running 24/7
    -pool 12X24, 11000 gallons, -1-1/2" plumbing, with 2 return, 1 skimer and 1 pool drain, -the pump is 25 feet away from the pool, -Pentair strarite supermax vs, -55000 BTU heat pump, -Hayward sand filter, -jacuzzi saniclear 20 SWG, -No elevation for the pool equipment, sit on level ground
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    Re: SWG Saniclear 20 too much FC
    What is your CYA level? The CYA level determines how high your FC should be. See this --> FC/CYA Chart
    Why not just turn your pump off? You don't need to run it so long daily....save the electricity Or just turn the SWG off when your level is higher than you want.
    Are you covering the pool in any way?
    Aug 2015
    Blainville/QC
    10
    Quote Originally Posted by YippeeSkippy View Post
    I cover the pool at night with a solar blanket and I also have a heater, it get cold at night 50 usually, so I need a both the solar blanket and the heater
    Jan 2012
    7,348
    Quote Originally Posted by shingo View Post
    Ok, well that is understandable. I guess I should have specified a cover such as an autocover that is closed during the day too?
