Thread: Rust stain removal
    Jun 2007
    Spring Hill, FL
    29
    Rust stain removal
    I used the vit c trick in combo with a puck and i worked great thanks to this site. Now my question is now the stain is gone whta happens to the rust is it filtered out over time or do I need to add something to bind the rust particals to get them to filter out?
    Gary
    14K Gallon IG Diamond Brite Finish
    24SF DE Filter
    Re: Rust stain removal
    The iron from the stain is now in the water. Depending on how much iron is in the water, you may need to use a sequestrant to keep it from forming stains again. If your fill water is iron free, you will eventually replace enough water to get the iron to go away.
