Results 1 to 10 of 10
Thread: Best Submersible Pump for pool draining
    Illupo's Avatar
    Jul 2016
    Scottsdale
    37
    Does anyone have a recommendation for a quality submersible pump? I have been renting a Wacker Nueson 2/3 hp from Home Depot, but at $29.00 per 4 hour rental, I would rather put the money toward something I own. I am looking at the Wayne, CDU 790 and it appears suitable to drain my 1800 gallon spa easily. I prefer to stay away from cheap plastic housings. Any thoughts?
    Inground 1800 gallon gunite spa/pool, installed mid 1980s.
    Pentair Clean and Clear Plus 4 cartridge filter Model CCP 240
    Pac Fab Challenger (High head, High flow) 1 1/2 HP pump
    One Jandy valve controlling automatic chlorinator
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,245
    Re: Best Submersible Pump for pool draining
    This is what I purchased:
    Flotec FP0S1300X-03 Tempest 1/6 HP 1, 470 GPH Utility Submersible Pump - Sump Pumps - Amazon.com
    The pump does not pump water as it claims, but is good enough for a swimming pool. They are very well built and I would not spend a lot of $$ on a pump unless the warranty went out 10 yrs. + and you used it quite frequently.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jun 2016
    Martinez, CA
    207
    2/3hp sump pump with floatswitch from harbor freight + 2" collapsible 25' hose they sell will move alot of water for under $90.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    Jul 2016
    Lynchburg
    3
    This guy should do the trick. Strong housing and it'll draw at 1470gph. Affordable and pretty good quality
    Tempestâ„¢ Water Removal Utility Pump 1/6 HP, 1470 GPH | FREE SHIPPING Flotec Pumps Store
    Jun 2016
    Martinez, CA
    207
    The 3/4 harbor freight is close to 3000gpm, stainless steel and $69 bucks. Mine worked great and emptied the pool very quickly.
    Jul 2016
    Lynchburg
    3
    $29/4 hours, no wonder you want to grab something for yourself. Flotec makes some pretty solid pumps.
    Illupo's Avatar
    Jul 2016
    Scottsdale
    37
    Thanks for all of the suggestions! Due to our poor water quality here in Scottsdale it would appear I need to dump the pool on an annual basis. Last dump was July 2015, and my TAP water measured 852 total dissolved solids as I was filling the pool! A year later, I am at 5000 TDS!! Good thing it is only 1800 gal! You can see why $30.00 a year in rentals (as well as the hassle of dropping it back off within 4 hours) it not very attractive.
    Any other pool owners in Scottsdale with such high TDS numbers or am I just lucky?
    Feb 2015
    Chandler AZ
    922
    Quote Originally Posted by Illupo View Post
    I'm just down the road in Chandler. Probably 15 miles or so from you. The water in the valley is high in CH, but otherwise pretty good. There really is no need to drain every year or two.
    TDS is irrelevant - just another tactic by the PS to sell you some over-priced potion. I see in another of your threads (Fabulous Forum!!) that you plan on ordering a TF-100. After you receive your test kit and the SpeedStir, post up your numbers in that thread.
    Is your pool 1800 gallons or 18,000 gallons?
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Apr 2013
    Sacramento, CA
    2,769
    The TDS really tells you nothing about you pool. Even many pool stores (other than Leslie's) ignore it. They can't even tell you why TDS is important.
    You need to get a TF 100 or K2006 and follow the TFP method.
    Illupo's Avatar
    Jul 2016
    Scottsdale
    37
    See, this is what I am talking about...every time I leave the pool store, I am more and more confused! Yes, I am happy to say that I ordered the TF 100 yesterday and it should be here next Monday. I can't wait to come back here and appear to know what I am talking about! Going to the pool store is like flying blind while being misdirected!!!!
    Yes, my pool is only 1800 gallons, I think they call it a spa/pool.
    Will be posting up numbers soon.
