Results 1 to 14 of 14
Thread: Jandy Aquapure purelink question....
    Jul 2016
    Manalapan, NJ
    6
    Hello. Does anyone know the part # for the board that goes behind the control panel in this pic?
    It's the board in this pic that's on the bottom (sorry for the partial pic) and has the wires coming out of it and the fuse.
    Thanks!
    Ron
    Jun 2016
    Martinez, CA
    207
    Re: Jandy Aquapure purelink question....
    What specifically do s your issue?
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Welcome to TFP!
    That looks like the back of an Aqualink RS primary power center main board which should be Jandy/Zodiac #8194. To confirm, there should be a part number just to the left under the other board.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Jun 2016
    Martinez, CA
    207
    If it s non functioning, the is a guy in norcal that repairs them. New replacements are ~350 from jandy and zero warranty unless a professional installes it. The repair guy is $150 and 90 day warranty. I just got mine back from him yesterday.
    http://www.bpelectronics.com/
    Jul 2016
    Manalapan, NJ
    6
    Quote Originally Posted by Rossterman View Post
    No power. I ordered a new transformer based on another thread pointing to that guy on ebay selling them.
    Quote Originally Posted by UN1017 View Post
    Welcome to TFP!
    Thanks!
    I will take it out and check on the board.
    I plan to send it out to him tomorrow. I already contacted him.
    The holders for the 3 amp fuse on the board broke so I have no power.
    Ron
    Jun 2016
    Martinez, CA
    207
    You could probably have that fixed at a local repair shop pretty cheaply if all it needs is to be resoldered and the chips on the board are OK. You could to bridge the fuse holder and verify that the board to works to be sure.
    Jul 2016
    Manalapan, NJ
    6
    The board was working before the loss of power issue. And the broken pieces are gone. Plus I wouldn't know what kind of place to bring it to.
    Is there any way though to run the pump while waiting for the board to return provided the transformer gets to me before the board does?
    Or is there anyway to run the pump now without the board and the transformer?
    Jun 2016
    Martinez, CA
    207
    Youd have to bypass the relay by moving the motor side wires and connnecting them to the power in side of the relay so the pump will run whenever the breaker is switched on. I did this on mine while the panel is out being repaired. Takes about 5 mins but you need to make sure everything is deenergized and comfortable,working with electrical wiring.
    Jul 2016
    Manalapan, NJ
    6
    Do you have a photo of this by any chance?
    Jun 2016
    Martinez, CA
    207
    Here's a crude sketch explaining it. You are essentially moving the same color wires to a single terminal.
    Jun 2016
    Martinez, CA
    207
    BTW got,the repaired board back quickly from BP electronics. Installed this morning andmeverything is working perfectly!
    Jul 2016
    Manalapan, NJ
    6
    Thanks. I'm awaiting a new transformer. Will this bypass still work without a working transformer? I'm not home to look now so this may seem like a dumb question, but which board/where is that relay?
    I have a NEW board coming tomorrow, as I mentioned in that other thread. ; )
    I diagnosed the transformer was bad after the breaker kept blowing and then put a voltmeter on it with guidance on the phone from an electrician friend to determine it was blown.
    I'm not an electrician but I am pretty handy. I took out the bad transformer and the bad board as well pretty easily.
    Thanks again!
    Ron
    Jun 2016
    Martinez, CA
    207
    This will work without the board even being installed. Since you are only a day away and not real familiar with wiring, I'd recommend waiting and reinstall the control board when it arrives vs. rewiring.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    And don't put that same fuse back in there, it's the wrong fuse. Probably why the tab on the holder broke. The fuse that goes in there is about half the length and half the circumference. The picture shows the existing fuse hanging over the edge of the panel possibly touching the panel (short)?
    Factory Warranty Station for:
