Results 1 to 14 of 14
Thread: 1st slam FC too high
    Jul 2016
    Saint Joseph, MO
    45
    Got the test kit last night, and the readings then:
    FC 10
    CC 1
    CYA 40
    PH 7.4
    Pump has been on 24-7
    This morning
    FC 9.5
    CC 0
    PH 7.4
    After family swimming all day:
    FC 7
    CC 0.5
    PH 7.4
    The water is still slightly cloudy, so I figure maybe try SLAM until it's clear. Problem is I added too much chlorine and now the FC is 26.5 with CC 0.5. Where do I go from here?
    CHAD
    24' Above Ground 46.5" deep, 13,147 gal
    Hayward E-Series 25GPM/m2
    Sand 200 lbs
    Hayward Power-Flo LX 1.5hp
    Taylor K2006
    Jul 2015
    Central Valley CA
    1,109
    Re: 1st slam FC too high
    Your SLAM level is 16 so you have been keeping it a bit low. Test just before you go to bed and again in the AM just so you can keep track. If it is still above 16 wait till around noon and see where it goes, try to keep it at 16 all day. Don't worry about the overshoot it will come down into SLAM range fairly fast just don't make a habit of it .
    I would continue the SLAM at least through tomorrow and try OCLT tomorrow night if the water clears by then.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jul 2016
    Saint Joseph, MO
    45
    Quote Originally Posted by atttech-2 View Post
    I only started slam tonight, after verifying I can titrate properly a few times! I'll let FC cruise down on it's own. BUT, how clear should the pool be before SLAM is finished? Right niw I can see the bottom fine, just not shining clear.
    CHAD
    Sand 200 lbs
    Taylor K2006
    Aug 2014
    Northern IL
    4,615
    Sparkling clear is your goal...!
    Jul 2016
    Saint Joseph, MO
    45
    Quote Originally Posted by MarianParoo View Post
    Like your profile pic? Good.
    Tested just now, and brought sample inside to test. I was very careful and got FC 27 and CC 2. The difference between 1 drop and 4 drops was very faint, but it really took 4 drops to clear CC. Check again in the early AM.
    OK to swim tomorrow?
    CHAD
    Sand 200 lbs
    Taylor K2006
    Aug 2014
    Northern IL
    4,615
    Test your FC before you swim. TFP recommends being below "shock" level, and that would be 15 or less for you.
    If you do swim, get back on the SLAM as soon as you are done. Those CC's indicate that you need some dedicated effort.
    Aug 2014
    Northern IL
    4,615
    Attachment 51827
    Forgive the old, balding guy. I do love him...
    Jul 2016
    Saint Joseph, MO
    45
    Great pic!
    This morning, 6:30am, FC is 25, CC is 0.5, and water is clearer than I can ever remember.
    No swimming?
    CHAD
    Sand 200 lbs
    Taylor K2006
    Jul 2016
    Saint Joseph, MO
    45
    Our pool gets about 5 hours of sun, an hour of that is part shade thanks to staining-debris-and-pollen-generating pecan trees. Those wouldn't be as bad id the squirrels didnt eat every single nut so we could have some.
    We did a 90% drain and refill of cloudy, slightly green water before receiving the test kit a few days ago. That 10% we left in there would be the cause of the problem.
    CHAD
    Sand 200 lbs
    Taylor K2006
    Jun 2014
    15,205
    Glad the water is improving. Correct, let the FC get down to at least 16 before swimming since your CYA was only 40. Have a great day Chad.
    Jul 2016
    Saint Joseph, MO
    45
    Still cruising. FC dropped to 16 today - lost 10ppm?? Yesterday it only dropped like 3ppm through the day. Anyway, that's not what's important now.
    I kept racking my brain to understand what else besides algae might be clouding the water just a bit. So, I bought a a Nature2 Express with the pool back 10 years ago. I haven't replaced the cartridge the last 3 seasons, but it's the kind where if the cartridge is removed water pours out. The old cartridge is on it's 3rd year. So I took it out this afternoon and it seems to have given the water more shine. Be able to tell better in daylight tomorrow.
    Added chlorine 45m ago and now FC is 22 and CC is 1
    CHAD
    Sand 200 lbs
    Taylor K2006
    Aug 2014
    Northern IL
    4,615
    Not sure what that means... But glad the Nature2 is empty! Didn't realize you had that going...
    Continue on with the SLAM!
    Jul 2016
    Saint Joseph, MO
    45
    This morning at 6:30am
    FC 22
    CC 0.5
    Water CRYSTAL CLEAR!
    Is it alright to let it cruise back to normal FC levels, and then test PH again once FC is under 10?
    CHAD
    Sand 200 lbs
    Taylor K2006
    Aug 2014
    Northern IL
    4,615
    Yes. Congratulations!!!!
