Thread: Can you use a variable speed pump witha Paramount in floor cleaning system
    Jul 2016
    Boston, MA
    4
    I am just about ready to install a new hayward VS pump and wondered if this will work correctly with my IFC system? Any thoughts or tips for this? Thank you
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Re: Can you use a variable speed pump witha Paramount in floor cleaning system
    It should work at lower speeds to filter the water but you'll probably need to run some hours at high speed to actually clean any debris in the water. I guess you'll have to experiment and figure out how many hours to run at high speed.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I run my VS pump at a higher speed for about 90 min each morning to allow my infloor system to do its job. It's just part of the daily program I have setup on the pump.
    chiefwej
    Feb 2015
    Chandler AZ
    938
    It will work fine. As chiefwej said, you will need to run it on a higher speed for the infloor to be effective. You will have to determine exactly what rpm that higher speed is for your specific pool. And you will also need to determine the high speed run time.
    On my system, I run for 90 minutes in the AM and 90 minutes in the PM at 2800 rpm. Then I run it for an additional 3 1/2 hours in both AM and PM at 1000 rpm. For my pool, this provides adequate cleaning at the higher speed and continued circulation/skimming during the remaining run time on low speed.
    How many hours per day have you been running with the single speed pump? Do you have a SWCG? Please add your pool to your signature as outlined here: Pool School - Read This BEFORE You Post
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    mas985's Avatar
    Pleasanton, CA
    11,741
    As other have said, it will work but running at higher speeds for longer periods make the economics of a VS less attractive.
    Mark
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If an infloor system is working properly, it should be able to clean the pool in a hour or two, then the pump can drop back to a much lower speed. With a VS pump you need to identify the lowest effective speed for each task and setup your programming accordingly.
    In my case, I use one speed for cleaning, a second for the SWG (chlorination, skimming and general filtration) a third, much lower for extra filtration. In addition a seperate speed is setup and activated by my solar controller anytime heat is called for and available at the panels.
    chiefwej
