Thread: Is it ok for sprinlkers to hit pool walls?
    Jul 2016
    Dracut/MA
    3
    I have a sprinkler system in my yard that was there before I bought it. When I had my pool installed I had to move a sprinkler head/line and lost a few heads along the process. I have replaced those with ones that are easily adjustable and pointed them away from my pool. However, some of the remaining sprinklers are being directed towards my pool walls.
    My question is, is this bad for my steel pool walls? I would think it's not ideal but should I go through the trouble of reaiming/replacing the heads so that they dont hit the walls? Or 20 minutes a day, 3 days a week wont do too much damage?
    The sprinkler heads in question are a K-Rain type (not sure model) and I cant figure out how to adjust them properly.
    14.5K Gal AGP, Waterway Hi-Flo II 2 speed pump, Cartridge Filter 150 Sq Ft
    Install 07/16, Taylor K-2006
    Apr 2013
    Sacramento, CA
    2,769
    Re: Is it ok for sprinlkers to hit pool walls?
    Yes you should re direct the heads. Putting water on the walls everyday will eventually cause a problem.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Do you use a well? I think it will cause stains...
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
