Thread: Sand in pool
    May 2009
    Trenton NJ
    497
    Sand in pool
    Replaced my multi port valve and laterals because I was getting sand in my pool. The multi port had a crack.
    Even after replacing I'm still getting sand in the pool and also notice on the ground after back washing.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Apr 2013
    Sacramento, CA
    2,769
    Re: Sand in pool
    How long ago did you replace?
    Is the sand decreasing? what does your system look like? How long have you beeen leaking sand?
    30,402
    Re: Sand in pool
    Confirm without a doubt it is sand. Pick some up between your thumb and forefinger and see if it is gritty like sand.
    Most posts of sand in the pool are really about dead algae.
    May 2009
    Trenton NJ
    497
    Re: Sand in pool
    Well it's definitely sand.......not sure what to do.
