Thread: 25mm vs 10mm FC test
    Aug 2015
    Ellis County, TX
    32
    Taylor kit - any difference in accuracy?
    17x33 Splash Alpha Pool, Pentair Tagelus TA60D sand filter, Pentair 1.5HP Dynamo Pump. Pool ladder, towel hooks, ice chest full of beer, green swim trunks.
    JoyfulNoise's Avatar
    May 2015
    13,247
    Re: 25mm vs 10mm FC test
    25mL sample size = 0.2ppm FC per drop of titrant
    10mL sample size = 0.5ppm / drop
    I typically use a 25mL sample size because I like the finer granularity of the test.
    Matt
    Aug 2015
    Ellis County, TX
    32
    Yeah I know the difference in drop scale, just wondering if it works out to be the same accuracy.
    May 2015
    13,247
    If your talking about testing tolerance, then this is the official tolerance for all drop based titration tests -
    When your drop count is ten (10) or less, the tolerance is +/- 1 drop. Anything over ten drops is +/- 10% if the final value in ppm.
    That is the case for 10mL or 25mL sample sizes. Your "resolution" is technically 1 drop. But, because drop volumes can vary with squeeze pressure and people can get sloppy, the more drops you add tends to cause a greater accumulation of errors. Therefore the tests resolution (how many drops you count) is not the same as the testing tolerance.
    Matt
