Results 1 to 9 of 9
Thread: What is a "return jet"?
    OutWest's Avatar
    Jul 2016
    El Dorado County, CA
    35
    I understand that it moves water around when the pump is on but does it bring water into the pool or take it out?
    Ignorant question, I know.
    I want to try using bleach but need to know where to put it into the pool.
    Thanks.
    Another quick question: My pool set up is to use chlorination tabs. Is it a problem to put the bleach straight into the water? The man who sold me the pool recommended against it. Said to use the tabs. Not sure why he said that but I'm all for anything that will save me money and time.
    8,900 gal in-ground gunite lap pool; self-cleaning Jandy 1.5 HP Pro Series E-pump system; Jandy CV340 pool/spa filter with four cartridges; Propane heater (rarely used); motorized pool cover.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: What is a "return jet"?
    A return is where water "returns" to the pool.
    If your sole means of chlorination is tabs eventually you will have a CYA problem. The articles in Pool School would be great, especially the ABCs of Water Chemistry.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    The skimmers suck the water from the pool the returns return it. Any return point......the thing water is coming out of on the side of the pool.
    Not really a stupid question. I know I didn't know (insert any word) about pools when my build was finished.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2011
    Long Beach, CA
    2,788
    OutWest's Avatar
    Jul 2016
    35
    Quote Originally Posted by ping View Post
    I did, but it didn't answer my question. Thanks, though.
    Quote Originally Posted by Mr Bruce View Post
    I did read it -- great info, and the reason I want to switch chlorinating method. Thanks for the answer.
    Quote Originally Posted by AimeeH View Post
    I fell terribly ill-informed. Thanks for saying that!
    30,421
    Put me on the ill-informed team, too. My first dealings with pools seem to me that the returns should "return" water to the pump.....where it started from.
    Jul 2014
    Sacramento, CA
    241
    Me too. It's opposite of heating/air conditioning systems terminology -- there the HVAC system is the focal point, with supplies sending air out to the house, and returns bringing air back to the unit. It took me a while and some misunderstandings to realized that, I guess, the idea is that the pool itself is the "star", so water gets sucked out of it, handled by the pump/filter, then "returned" back to the pool.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Sep 2015
    Rome, NY
    363
    Like an air return with HVAC!!
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    OutWest's Avatar
    Jul 2016
    35
    So I turned the pump on a couple nights ago, found the return jet (thank you all!), and poured in the bleach. Then the pump seemed to stutter and the water wasn't coming in very well. So I figured I need to work on the cartridges more. I shut everything down. Am soaking the cartridges in soap overnight and will hose them tomorrow. Have ordered a pool vacuum that I'm hoping will get the silt up off the bottom. Then I guess I'll check the chlorine again and carry on with pouring bleach in front of the return jet. I must say, this is complicated in a lot of ways but is oddly straightforward now that I understand the basics of the equipment and the chemicals.
