Thread: Deck around semi inground pool - Pool Bonding?
    Nov 2014
    North Bergen, NJ
    15
    Ok.. I wasn't sure where the best spot for this post would be so I picked this thread.. I have an 18x33 semi inground pool. The pook equipment (heater, filter, pump, extra outlets, swg, etc) is located on a pad approximately 12ft away from the pool edge.. When the pool was installed the electrician bonded the pool which included running a wire around the perimeter of the pool and tying it into the skimmer, return, pool equipment. He then asked if we were installing a metal ladder to get in as it would also need to be bonded.. I informed him that we were planning on building a small platform made of composite decking.. He brushed it off as if it did not need bonding.. Well the "platform" idea turned into a full deck build.. I looked around online and the only times I see pool bonding in reference to a "deck" is when the word "deck" is used to describe a concrete surround.. Has anyone installed a deck (wood or composite) around their pool and had to bond it? I have tried searching online and everything with pool bonding refers to "decks" that are pavers, concrete, etc.. I have yet to find anything about bonding a wood or composite deck.. The deck we are building has a traditional wood undercarriage and then composite planks/trim and pvc railing.. Thank for any input...
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: Deck around semi inground pool - Pool Bonding?
    I never heard of it and think you're golden. The deck probably doesn't even have any contact with the pool, correct?
    Nov 2014
    North Bergen, NJ
    15
    Quote Originally Posted by woodyp View Post
    The deck has no contact with the pool other then the staircase going into the pool. We opted for the grand staircase which I think I have heard refered to as the wedding cake stairs... The stairs have a plastic piece that extends from the rails which screws into the deck for stability..
    Apr 2010
    East Texas
    9,581
    Go for it!
    May 2012
    Montville NJ
    545
    Bonding keeps two conductive items that are not touching at the same potential. You could have your pool wall at one potential, and the ground at a different potential. If you touched both at the same time, then your body would bridge that potential, and it would balance itself through you - I.e you would get a "shock". Bonding provides a low resistance path between all of these various conductive items, alowing the different potentials to equalize.
    Seeing as your deck is composite, it is non-counduitve, and does not need to be bonded. Steel reinforcement in concrete decks does need to be bonded.
    You can even have different parts of the ground at different potentials. You take a step, and the potential equalizes by going up one leg and down the other. If you are working around telephone poles, and there is situation where the pole becomes energized, well you first choice is to stay in the vehicle. If you have to leave (maybe your vehicle is on fire) you shufffle away, to avoid any ground potential rise. Not that this will happen around you pool, but still, its interesting.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,770
    While the wooden deck doesn't need to be bonded if you install any outlets on the deck with metal conduit the conduit must be bonded. If you use plastic conduit that doesn't need to be bonded but the outlets must be properly grounded and gfci protected. Any permanently installed metal, like screwed down and part of the deck, within 5 feet of the edge of the pool should be bonded. For example if you used metal railing on the edges of the deck that should be bonded. More than likely though you will have nothing on your deck that needs bonding. Happy deck building, its been almost 2 months for me and I still haven't finished my deck. Some how the deck has ballooned to about 1000sqft I now refer to it as the project that will never end.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
