Results 1 to 12 of 12
Thread: Reducing Suction on Vacuum head.
    Jan 2010
    Randleman,NC
    620
    Since installing new pump.Suction is to much when cleaning.Just suck's head to the floor and hard to pull & push.Low speed is not enough so is there any other suggestions to cut the suction back?I did turn my skimmer valve back a little and tried.Not much help.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Reducing Suction on Vacuum head.
    Quote Originally Posted by kplaster View Post
    Sent from my XT1030 using Tapatalk
    Are you closing any suction valves that the vacuum is not connected to?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jan 2010
    Randleman,NC
    620
    No other valve's
    mas985's Avatar
    Pleasanton, CA
    11,741
    Do you have a shut off valve on the pressure side of the pump? Throttle flow down a bit using that valve.
    Mark
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    I'm at a loss.
    My only thought would be an older vacuum head with bristles worn down? (Mine is). my cheap vacuum head for a vinyl lined pool has a rubber gasket like thing on the outside of the triangle head and sometimes that rubber part slips off a little (despite my efforts of gluing it back in place) onto the bristles which causes the vacuum head to have more suction to the floor that the bristles normally prevent.
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by mas985 View Post
    No,The pool guy who hard plumbed didn't put one in after I asked him to.S o that's not a option now.Going to add one when I closed it up for the year.
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by AimeeH View Post
    I'm at a loss.
    Head is fine.Not the problem.Just to much suction.I always take my hand and check for suction before vacuuming.Today it got my hand and I didn't think I was going to come loose.Was in the water &by myself.Scary!!!
    mas985's Avatar
    Pleasanton, CA
    11,741
    How do you clean the pump basket without a valve to shut off the pool flow to the pump?
    Mark
    Jan 2010
    Randleman,NC
    620
    Yes & close the multi-valve.I closed the skimmer valve a little &couldn't tell much difference.Didn't want to starve the pump.
    30,431
    If your skimmer valve is the only way to restrict flow keep a close eye on your pressure gauge.....don't let it drop too low. What was your psi before you started restricting the flow?
    Jan 2010
    Randleman,NC
    620
    I didn't check.I was in pool today and reached over and closed just a little.I need to add a valve on return side.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    There is a vacuum head with adjustable bypass. I'll try to find the post about it.
    pump basket air - should there be any?
    Hope this helps.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
