Results 1 to 8 of 8
Thread: Spa plumbing air line
    Jun 2014
    toronto,on
    39
    I'm just about to finish up the plumbing for my spa and I would to see if anybody know if the air lines should be looped. I can't seam to get to a few area so I was just going to tee off another jet and cap the one end.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Spa plumbing air line
    No need to loop an air line around the spa. They have very little loss if large. Just keep the pipe large (2.5") close to the venturi tees.
    Are you planning to put in a Hartford loop?
    Mark
    Jun 2014
    toronto,on
    39
    Thanks
    Yes Hartford loop, 2.5" supply lines down to 2" at jets and the air line is 1.5". The equipment is about 3'-4' away.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Air line is 1.5"? That is really small even for 3'-4' run. I would use minimum 2".
    Mark
    Jun 2014
    toronto,on
    39
    That's what the jets have. Should I up size at the Hartford loop?
    mas985's Avatar
    Pleasanton, CA
    11,737
    I would keep the air line the same size all the way back to the pad. Smaller air lines will create more noise not to mention less bubbles.
    Mark
    Jun 2014
    toronto,on
    39
    I understand what you're saying, but the waterways jet bodies have 1.5" air lines and the Hartford loop is already buried in concrete so the only option is to up size at the loop to the pad. Do you think this will help?
    mas985's Avatar
    Pleasanton, CA
    11,737
    It couldn't hurt. At least the noise won't be as bad.
    Mark
